Thread: Door pillars
    Regular Member Chuddy's Avatar
    Jul 2009
    Derbyshire
    Vehicle : 3.2 gsi
    Trim : gsi
    Engine : 3200
    Default Door pillars
    Anyone any idea if the exterior door pillars come off or if they permanent to the door?
    Bought some 3m carbon fibre to wrap them in but dont fancy the idea of cutting round it whilst on, due to maybe catching the rubber seal with the knife during cuts. Plus the fact i could do a much better job with them already off.
    Any help appreciated guys. Cheers
    WGAF#5
    Quite easy to do... just let the windows down and then pull the rubber seal outwards that sits in the trim,you will see about 3 or 4 screws holding the trim securely, once they are released pull the trim backwards as it lips around the back edge of the door.
    its one of those jobs that becomes self explanetary once you start messsing!
    Regular Member Keif's Avatar
    In the Garage
    Sounds difficult, but it's dead easy.
    However, to keep the tension in the vinyl to help reduce any air bubbles, i'd strongly recommend, removing the rubber seals out of the way and wrapping them on the car, then take them off to trim any excess off.
    Will also help lining up the "carbon weave" on the vinyl.
    I took mine off and wrapped them in black vinyl, i wish i'd done them on the car, would have been alot easier and less bubbles to remove afterwards
    Regular Member Dan.'s Avatar
    milton keynes
    was thinking of doing these but might buy the gen irmy kit
    Jul 2009
    Derbyshire
    Vehicle : 3.2 gsi
    Trim : gsi
    Engine : 3200
    Cheers for info guys Will give it a bash the next sunny day i get that i have spare time! Could be a while as im a landscape gardener lol.
    newport
    if you get the 3m di noc range of carbon fibre, the adhesive on the back has channels in them so you are a lot less likely to get airbubbles in it over standard vinyl
    SCOTLAND
    I like the irmy kit as it is not dull like the carbon fibre. Prefer a more laquered shine if you like but not sure if you get that or if the di noc stuff is all matt finish.
    In the Garage
    Quote Originally Posted by Graeme View Post
    You want plain old black vinyl.
  1. Door Pillars
    By Tam80 in forum Bodywork & Interior
    Last Post: 21st June 2011, 19:38
  2. Door pillars
    By Ralphwells1967 in forum Vectra C / Signum Car Chat
    Last Post: 14th April 2010, 08:49
  3. Door Pillars
    By Danwells72 in forum Vectra C / Signum Car Chat
    Last Post: 10th December 2009, 00:21
  4. door pillars
    By keith1983 in forum Styling
    Last Post: 9th June 2009, 00:14
  5. Carbon door pillars
    By Brocks in forum Styling
    Last Post: 9th June 2006, 07:50
