Thread: Fault code P2279 Showing.HELP!!!.Info PLEASE.
    stockport
    Exclamation Fault code P2279 Showing.HELP!!!.Info PLEASE.
    I have just replaced my EGR valve last weekend because the car kept going into limp mode.This happened on a couple of occasions so,seeing as the car has 93k on the clock,I thought it was worth doing.However,it happened again then went back to normal running.
    Yesterday my wife drove to Birmingham Airport from the Manchester area with no issues whatsoever.Then,today, after going into Manchester town centre it went into limp mode.First the spanner light then the EML came on and stayed on.
    When I coded it I got P2279,Air intake leak,and on driving the car around the estate,could tell it was still in limp mode.I cleared the codes and reset the EML and it drove normally!!.No problems whatsoever.
    Can anyone help in what might be the problem?.I would be eternally grateful.
    FELIXX.
    Vehicle : vectra-c
    Trim : sri
    Engine : cdti
    Mileage : 98,000
    It sounds like you have a leak somewhere from where its monitered at the maf on the intake through to the manifold, check all pipes including intercooler, check your egr gaskets also, gotta be something simple.
    morecambe
    48 Post(s)
    Vehicle : vectra
    Trim : vxr
    Engine : 2.8 v6 turbo
    as above
    Full Member
    Jun 2007
    N/A
    Vehicle : Golf 7
    Trim : GTD
    Engine : 2.0 TDI 184PS
    Mileage : 40000
    If you can't see anything obvious under the bonnet, then I would say the intercooler maybe developing a leak.
    Gazza4
    stockport
    Exclamation
    Quote Originally Posted by the-wizard View Post
    Thank you all so far,for your replies.I have had a cursory look inside the engine bay and checked all the pipes that I could see.There doesn't seem to be anything amiss in that direction.
    Regarding the EGR,it seems to be firmly in place,however,I had noticed that when I took it off originally,that the power connector fitting was dodgy in that the locking tab wasn't locking,and I am wondering if that worked loose,could that throw up that code?.Also,apart from looking for obvious signs in the hoses,would there be any audible sounds given off if there is a problem with the intercooler?,and if the problem is a "realtime" problem,wouldn't it have happened again straight away after clearing the codes and running the car etc?.FELIXX.
    Full Member
    Jun 2007
    N/A
    Vehicle : Golf 7
    Trim : GTD
    Mileage : 40000
    An EGR valve which is not functioning properly - ie not opening fully will give fault code P0400 - Exhaust Gas Recirculation Flow Error.
    Gazza4
    stockport
    Arrow
    Quote Originally Posted by Gazza4 View Post
    Gazza4
    I was grasping at straws really.I just can't understand why it will go like stink,then suddenly go into limp mode then be ok again!!.FELIXX.
    Full Member
    Jun 2007
    N/A
    Vehicle : Golf 7
    Trim : GTD
    Mileage : 40000
    Quote Originally Posted by felixx View Post
    Like i said, the intercooler would be my first port of call.
    Gazza4
  1. P2279 Fault Code - Ait Intake Leak
    By McLovinH in forum Engine & Drivetrain
    Last Post: 20th September 2012, 17:54
  2. Fault code P2279?
    By Phil MC in forum Engine & Drivetrain
    Last Post: 8th July 2012, 19:29
  3. 1.9 CDTI fault code P2279-11
    By mozzer99 in forum Engine & Drivetrain
    Last Post: 14th June 2011, 20:13
  4. P2279 code. 1.9 150
    By Mopar Man in forum Diesel Engine related
    Last Post: 28th April 2011, 20:45
  5. fault code p2279
    By decks in forum Vectra C / Signum Car Chat
    Last Post: 20th November 2010, 20:14
1.9 cdti egr valve code p2279
p2279 code cleared car going ok
