Thread: Engine / Thermostat Identification
    Regular Member brianjamesreed's Avatar
    N Ireland
    Default Engine / Thermostat Identification
    Hi guys
    Help please.
    I am looking to replace the thermostat on my Vec C 2.0DTI 2004.
    Almost everything I read says thet the whole thermostat housing has to be replaced but I have seen a couple of references where just the thermostat has been replaced.
    Has anyone here got the info, supplier or part numbers for the thermostat on its own?
    Maybe other models with the Y20DTH engine have replaceable thermostats or do they have different housings? Are all Y20DTH engines the same as my 2004 model?
    Someone on here said the stat out of a Quinton Hazel QHT600T is all that is needed but what stat is this?
    Maybe someone with more intimate knowledge of the Vectra B and Vectra C will know if parts can be exchanged.
    If we can work this out I would be happy to do a HOW2 for everyones benefit.
    Wirral
    Engine : 1.9CDTi
    Mileage : Lots
    I did the thermostat on my 2.2 DTi a few weeks ago because it was knackered. I ordered the part from the VX dealer and it was about 40 quid. I'm not sure if the part number will be the same for the 2.0 as the 2.2 though. It was the whole thermostat housing that came. From what I remember seeing, I don't think the thermostat itself could easily be removed from its housing. All the engines are the same as far as I know. I suppose you could remove it and test it in boiling water if you suspect it is at fault. Do you know where it is on the engine?
    Devon
    78 Post(s)
    Vehicle : insignia
    Trim : irmscher
    Just got mine the other day cost me £14.98 from Car parts connexion
    Here's part number 24420728
    And here's a link to one for £14.58 HTH
    http://www.carpartsconnexion.com/vau...del&y=Any+year
    Irmscher Insignia CDTI 130
    Wirral
    Engine : 1.9CDTi
    Mileage : Lots
    15 quid?!
    Balls. Can't take it back now.
    Regular Member Innes's Avatar
    Plymouth
    I've got a 2.2dti and replace the thermostat for £12 from a local auto shop. I didnt have to replace the housing but you do need to replace the gasket which is available from Vauxhall. I cant remember how much, maybe a quid?
    Plymouth
    N Ireland
    Default Re Thermostat
    Cheers guys
    Re 2.2.dti stat. Do you have a part number or even the make and I could reseach it further.
    Re 15quid stat. Rang them but now out of stock and quoting £58 for new stat/housing and gasket.
    Anyone else any info.
    Travelling for a few days but will look in.
    Changed the temp sender unit last night and only reinforces my belief that the stat needs replaced. Will be doing it next week one way or another so any input re replacing just the stat will be a great money saver.
    Cheers again
    Regular Member costalot's Avatar
    shropshire
    where ie the state located also the temp sender
    Bristol
    Vehicle : CDTI 150
    Quote Originally Posted by costalot View Post
    Passenger side of engine, towards the top/front. The temp sensor screws into the thermostat housing.
    N Ireland
    Default Stat Changed
    Sorted.
    The stat can be changed on its own. Use Quinton Hazell part QTH600K and a new Vauxhall Gasket. Total cost around £16.00
    Check out the how2 section when my post goes live.
    BJR
  1. whats normal time for thermostat to warm up engine on 120 8v
    By firebeast in forum Vectra C / Signum Car Chat
    Last Post: 30th November 2013, 16:58
  2. Is my X18XE engine thermostat failing AIGAIN
    By coldo in forum Engine & Drivetrain
    Last Post: 16th October 2012, 19:28
  3. Is my X18XE engine thermostat failing
    Last Post: 27th November 2011, 20:30
  4. Faulty thermostat, does it damage the engine ?
    By deanos in forum Vectra C / Signum Car Chat
    Last Post: 3rd May 2011, 07:23
  5. Engine identification plate?
    By JoeDaShmoe in forum General Chat
    Last Post: 9th June 2009, 20:34
