Thread: still struglin a bit
    morecambe
    37 Post(s)
    Vehicle : vectra
    Trim : vxr
    Engine : 2.8 v6 turbo
    Default still struglin a bit
    again on with the tid to gid everything works fine its gettin tech to tomorow what will happen if i dont have the two wires in the diag plug do i just literally plug them in the plug or do they need wirein in to the back of the plug see the description from the how 2 below please thanks but After this is all done you may need to fit a washer bottle sensor and a Wiper stalk with BC controls
    The wiper stalk will need to be Tech2 to your car so you can clear any check controls that pop up
    As far as i'm aware you will have to fit an additional 2 wires to the GID and Diagnostic plug to enable all BC (board computer) functions these are pins 22,23 on Gid all i did was add 2 pins onto end of 2 lengths of wire then added pins from a old vectra b Diagnostic plug to the other end and slotted them into pins 3,11
    Pin 22 goes to Pin 3 on the Diag plug
    Pin 23 goes to Pin 11 on the Diag plug
    morecambe
    37 Post(s)
    Vehicle : vectra
    Trim : vxr
    anyone
    Regular Member Morephun's Avatar
    everywhere
    Vehicle : vec c
    Trim : sri
    Engine : 150 cdti
    Year : 55
    Mileage : 108000
    think everyone has died reading this from lack of air
    morecambe
    37 Post(s)
    Vehicle : vectra
    Trim : vxr
    prob mate lol
