Thread: Cams...
    Jul 2006
    Northampton
    Trim : Sri
    Engine : 1.9 cdti 150
    Default Cams...
    I watched wheeler dealers yesterday and they fitted high lift cams to their rover v8 and it gave me a thought. so does anybody know if high lift cams will be any good on a diesel?
    Regular Member Rab's Avatar
    Irvine
    cams can be done to any engine.
    weather its worth the cost, no.
    cams on a turbo car is something thats saved till after a turbo upgrade.
    cams on a N/A engine fine but on a diesel i think not.
    diesel most tuning companies see the limit after
    intercooler
    custom map
    hybrid turbo/or bigger
    turbo back decat exhaust
    some form of uprated induction
    extreme cases
    fuel pump
    injectors
    after this level should buy a bigger diesel engine e.g. bmw's 3.0 twin turbo
    or a high power petrol. after so long your defeating the purpose of the diesel?
    Jul 2006
    Northampton
    Trim : Sri
    mmm... i am planning to get a v6 turbo charger and have done the rest apart from the remap(which will be last). maybe i will pass on this but will speak to a tuner before getting the remap done
    Irvine
    is the V6 any bigger? you may find the turbos the same just on a bigger engine? dont know tho.
    have you considered sending your stock turbo away to be swapped for a refurbished one which has been turned into a hybrid.
    Jul 2006
    Northampton
    Trim : Sri
    i have spoke to a turbo company at pvs this year and they said there is nothing the can do with variable vane turbos, nobody can. But that doesnt change the fact that i could exchange for a bigger variable vane turbo. I believe the v6 turbo is bigger and there are a few posts stating that.
    morecambe
    48 Post(s)
    Vehicle : vectra
    Trim : vxr
    Engine : 2.8 v6 turbo
    what car is yours dan
    Jul 2006
    Northampton
    Trim : Sri
    2.2 dti
    Regular Member Jezzy's Avatar
    S.E
    Don't forget that the Land Rover has the engine mounted longitudinally, so access to the camshaft was relatively easy with the engine block still in place.
    Jul 2006
    Northampton
    Trim : Sri
    TBH it was just a thought for the future, i doubt i will go ahead with it as it doesnt seem worth doing and also i may loose some low end torque which i dont want to do
    EVERYWHERE
    High lift cams are usually used to make engines breathe better and therefore rev higher, they also make the idle lumpier. They work really well on petrol NA engines if you don't then mind the gutless nature of the power delivery.
    Diesels are different, they don't require 'wild' cams to make power. If you want more power from a diesel you merely need to increase boost along with the amount of fuel injected. Theoretically you can keep on doing that until the engine blows up! You will get more power, but not at much above 4000rpms.
    There was a 'head kit' available for the 1.9 in a thread a few weeks back. Waste of time for diesels IMO.
  1. cams
    By HARRY SRI in forum Diesel Engine related
    Last Post: 17th April 2012, 15:55
  2. 3.2 v6 cams???
    By jackharrison12000 in forum Petrol Engine related
    Last Post: 25th May 2011, 17:15
  3. Cams
    By Danwells72 in forum Diesel Engine related
    Last Post: 11th January 2010, 20:16
  4. J cams
    By chris26gsi in forum Vectra C / Signum Car Chat
    Last Post: 9th December 2008, 00:04
  5. Cams
    By Dave1.8 in forum Vectra C / Signum Car Chat
    Last Post: 31st January 2008, 12:41
