Thread: 2.2 sri vibration
    Oct 2010
    york
    Default 2.2 sri vibration
    Hi everyone, hope someone out there can help pleeeeease. Had cam chain replaced as car had vibration as you accelerate, only problem is car still doing it, seems like you are in fourth gear and doing 20 mph and you accelerate, only problem is its in first and second gears, you can feel it through the gear stick and engine, cruises fine at all speed , drive shafts fine, has anybody had the same thing with their vectra or does anybody have an idea as to what it could be please ?
    Regular Member rushy's Avatar
    Vehicle : SRi
    Engine : Z22SE (2.2 Petrol)
    Mileage : 137000
    There is another chain on the 2.2 that operates the balancer shafts, did you change that as well and if so was it timed properly?
    Oct 2010
    york
    yep both done for £760, what happens if egr valve is sooted up , what are symptoms as car covered 78k.
    Vehicle : SRi
    Mileage : 137000
    Quote Originally Posted by lordreeson View Post
    . TBH the EGR doesn't really get much grief on the 2.2 but it can stick. Take it off and give it a quick clean, you can bench test it HERE. Just pass 12v over pins A&E. I don't really think it would cause a vibration though. Could it be clutch related? Maybe misaligned?
  1. vibration
    By steve19cdti in forum Engine & Drivetrain
    Last Post: 11th April 2011, 07:32
  2. Vibration
    By Si-SRI in forum Vectra C / Signum Car Chat
    Last Post: 12th October 2010, 20:46
  3. vibration
    By rich2507 in forum Engine & Drivetrain
    Last Post: 21st April 2010, 17:12
  4. Vibration through car
    By Orbilator in forum Vectra C / Signum Car Chat
    Last Post: 25th August 2008, 21:13
  5. vibration
    By Eddy R in forum Engine & Drivetrain
    Last Post: 20th August 2007, 19:59
vectra c 2.2 sri engine vibration
vectra c 2.2 vibration when accelerating
