Results 1 to 10 of 21
Thread: gearbox rattle
    Aug 2010
    herts
    Question gearbox rattle
    just noticed a rattle coming from the gear box on my vectra c 2.0 sxi t, on 46,000, 2003,it only rattles when you rev it up and just before the revs die down it rattles can hear it more fro the passengers side wheel area, also when i put it in reverse these a clonk car jumps slightly, also 2ND gear slight crunch when going from 1st to 2ND any suggestions please
    Aug 2010
    herts
    any advice anyone please!!!
    north east
    Front engine mount most likely, a bad design at best .. im awaiting the powerflex bushes to be made before replacing mine.
    Aug 2010
    herts
    the noise is definitely coming from the gear box behind the passengers wheel its like tapping noise.
    north east
    get someone to rev the engine while you watch, its will be rocking back and forth (back revs increase ) forth was they decrease if its the front mount, normaly in 3rd gear you wont hear it as the torque is holding it in the back position.
    this what it looks like
    http://cgi.ebay.co.uk/vectra-c-1-9-c...item3a5fc5f834
    The wall between the cut out sections is very narrow and once it brakes away thier is a lot of play.
    If you can get under to check it out when you get a new one fill the gaps with some black silicone.
    Regular Member Rebellion8878's Avatar
    Jul 2009
    Bucks
    Had this on my astra was a tensioner on the cambelt.
    Aug 2010
    herts
    i will have another look tomorrow but I'm still convinced its coming from the gear box also first thing in the morning when i pull away in 1st gear then change to 2ND it fells like it jumps or slams in gear when i release the clutch out ?????
    Aug 2010
    herts
    forgot to say that when i push the clutch in it wont make the rattle noise when i rev it.
    north east
    Yeah the mount attaches to the gear box .
    heres a broken one .. less usefull than a paper brick.
    http://cgi.ebay.co.uk/vectra-c-1-9-c...item3a5fc64236
    this is its location on the sub frame the top of the pic is the passenger side wishbone point
    http://cgi.ebay.co.uk/VAUXHALL-VECTR...item230ad8f501
    Aug 2010
    herts
    cheers Roswell will check that out, dose my 2.0 sxi turbo have a dmf if so would this make this rattle noise I'm getting also could it be the clutch???
  1. M32 gearbox can`t get gear selector back in gearbox HELP!
    By v33tra in forum Engine & Drivetrain
    Last Post: 30th March 2017, 07:43
  2. Clutch / Gearbox noise / rattle CDTi 150
    By Paul_B in forum Engine & Drivetrain
    Last Post: 1st March 2013, 17:21
  3. Strange rattle from gearbox. 3.2 V6
    By mammix2 in forum Engine & Drivetrain
    Last Post: 28th August 2008, 21:00
  4. Rattle rattle boooooom!!
    By Triple Trouble in forum Vectra C / Signum Car Chat
    Last Post: 8th August 2006, 08:44
