Thread: Question about remote keys!
    May 2008
    High Wycombe
    Default Question about remote keys!
    Hi
    Vectra 1.8i Petrol '07
    1. I have 2x remote keys for my car. 1st key sometimes the remote locking/unlocking will not work and i have to get in the car with using the key in the lock rather than remotely. When it does work (most of the time) then the distance it works from is really good (50m+) Could this be the battery?
    2. The 2nd key has not worked remotely for a few months. This is i'm sure the battery being dead. When i replace the battery will it still work or do i have to get it re-programmed with vauxhall?
    3. My wife has a Astra 1.8i petrol '06 and her key remote is getting a little temperamental and she has to get nearer the car for it to work. Think i'm right in saying that this is also a battery problem, correct?#
    Thanks for any answers
    Matt
    Sep 2010
    Hartlepool
    I would replace the battery in the remotes and give the contacts where the battery goes a good clean while you're in there.
    Once you've changed the battery, you will have to open your car using your key in the lock on the driver's door and start the car with each key to re-program the remote part.
    I had a similar problem a few weeks ago and this worked.
    HTH.
    May 2008
    High Wycombe
    Excellent. What's the deal with changing the battery....how long do i have to do it in?
    11 Post(s)
    I don't think there is a time limit as such, but I remember reading in a handbook somewhere that if you take longer than 3 minutes or you accidentally press any of the fob buttons while the battery is removed then you'll have to resync as per the procedure mentioned by RichyA.
    All the info, re battery change and resync procedure is documented in the handbook.
    May 2008
    High Wycombe
    Okay thanks Dave!
  1. Keys
    By Danwells72 in forum Vectra C / Signum Car Chat
    Last Post: 29th February 2012, 23:52
  2. Help with keys please
    By Splid in forum Electrical & ICE (including SatNav)
    Last Post: 27th January 2012, 15:47
  3. Remote Key Fob Question... Aarrgghhh!!
    By Signum7060 in forum Vectra C / Signum Car Chat
    Last Post: 26th April 2011, 17:25
  4. keys
    By wullie.d in forum Vectra C / Signum Car Chat
    Last Post: 9th February 2011, 21:24
