Thread: Upgrading brakes?
    Regular Member bedo13's Avatar
    Oct 2009
    EgypT
    Default Upgrading brakes?
    For upgrading brakes..
    Is it satisfying to change rotors with EBC ventillated & grooved rotors of the original size or i should buy bigger size (300 mm or 345 mm)??
    What is the original size? (mm?)
    Regular Member Jezzy's Avatar
    S.E
    Oct 2009
    EgypT
    thanks alot
    But which is better:
    285mm ventillated and grooved rotors or 302mm origina rotorsl?
    S.E
    All the front brake sizes on the Vectra-C are already vented, only the smaller of the two rear sizes are not vented. 302mm (vented) disks will be better than the smaller ones, even if the smaller ones are grooved. To upgrade to bigger disks you will also need to change the caliper and carrier.
    Regular Member OPC's Avatar
    Notts/Lincs
    Vehicle : Vectra-C
    Trim : SRi XP2 Nav
    Engine : 1.9 CDTi 150
    A set of 314mm discs and matching calipers will give a very satisfying results and i'm sure there is plenty of reading on to to back this up, the calipers alone are the same size as the VXR's.
  1. Upgrading 1.9cdti brakes
    By PeteD in forum Handling & Braking
    Last Post: 21st April 2012, 20:49
  2. Replies: 14
    Last Post: 3rd September 2011, 20:23
  3. Upgrading to sat nav
    By fastcarmanaic in forum Electrical & ICE (including SatNav)
    Last Post: 24th June 2011, 11:26
  4. Upgrading brakes fitting costs
    By Danger_MouseUK in forum Handling & Braking
    Last Post: 23rd May 2011, 15:25
  5. Upgrading my 3.2 V6
    By Vectroid in forum Tuning
    Last Post: 25th March 2007, 00:13
