View Poll Results: Do you suffer from bad warm starting
Voters
71. You may not vote on this poll
  • 2.0 Dti Yes
    14 19.72%
  • 2.0 Dti No
    19 26.76%
  • 2.2 Dti Yes
    14 19.72%
  • 2.2 Dti No
    24 33.80%
Results 1 to 10 of 18
Thread: 2.0/2.2 Dti poor starting from warm
    Admin & Merchandise Manager bigmac's Avatar
    Devon
    62 Post(s)
    Vehicle : insignia
    Trim : irmscher
    Default 2.0/2.2 Dti poor starting from warm
    Following on from numerous threads regarding poor starting i thought i would make a simple poll about the problematic starting when warm on the 2.0/2.2 Dti.
    Like most mine starts fine with Glowplugs and fine when Hot but its in between this when it get bad and numerous cranks to start and white smoke.
    So i just want to know how many of you's have this problem when warm eg: When its not cold enough for Glowplug light to come on or if you leave it for an hour after cold start then return.
    Irmscher Insignia CDTI 130
    Regular Member Dazzy2006's Avatar
    Notts
    mine is fine starting from hot and cold but as you say if warm seems to take a couple of extra cranks to start
    Devon
    62 Post(s)
    Vehicle : insignia
    Trim : irmscher
    Do you get white smoke ? unburnt diesel
    Notts
    i just get a quick puff of smoke but nothing major
    Nottinghamshire
    Voted Yes for 2.2 DTi. I never had a starting problem for nearly 8 years then all of a sudden it starts playing up when the temperature dropped a week or so ago. See the thread for details...
    http://www.vectra-c.com/forum/showthread.php?t=121174
    Regular Member si_hoss's Avatar
    Apr 2009
    Stevenage, Herts
    Also voted YES for 2.2DTi. Was starting fine until about May this year, been poontang, now glow plugs are coming on it's on the button!
    I've replied on some other threads recently, but really keen to resolve this!
    Full Member paul.sessions's Avatar
    leighton buzzard
    Forfar, Scotland
    Trim : LE/VXR
    Engine : 2.0 cdti/1.6 Turbo
    Year : 13/07
    Glow plugs pah, shotgun cartridge for me
    http://www.youtube.com/watch?v=S1rc3...eature=related
    Vehicle : Signum 2.0 DTi
    Trim : Elegance/Elite
    Engine : 2.0DTi
    Mileage : 73350
    Allthough i have not had a starting problem , I have allways had the glow plug problem were it brings up the dreaded spanner light when the car is first started a problem which had existed ever since i first got the car 3 1/2 years ago. This had become noticeable worse over the last couple of weeks with a fair bit of hesitancy with the engine when running .
    So i opted to change the glow plugs , result no more dreaded spanner light and no more hesitancy when the engine is running .
    One thing i also did was to put a multi metre over the plugs the new ones before installation were reading around about the 5-10 ohm mark .
    But off the old ones two were fairly low one reading about 15 ohm and the other about 25 ohm the other pair were of the scale reading 147 and 265 ish .
    Conclusion to all this glow plugs are much like spark plugs they detiriate over time and should be replaced whenever ignition problems exist . the ohm,s test can be done with the plugs still in the car to give you an idea off whether or not the plugs are on the way out and for what they cost , i paid £32.45 for a set off E bay from vauxhallpartswharehouse were as the stealers want around £55-60 for a set its a bit of a no brainer to do it.
    hope this helps someone on there quest for the perfect engine .
    and still loving it
    Wirral
    Engine : 1.9CDTi
    Mileage : Lots
    No problems at all in mine.
  1. Warm starting problem
    By sheddy in forum Engine & Drivetrain
    Last Post: 7th January 2013, 22:27
  2. warm starting issues
    By supersteve_75 in forum Troubleshooting
    Last Post: 7th June 2012, 17:55
  3. poor starting when warm
    By ron broughton in forum Engine & Drivetrain
    Last Post: 24th February 2012, 11:40
  4. Bad starting From Warm
    By viper8 in forum Vectra C / Signum Car Chat
    Last Post: 7th April 2011, 19:06
  5. DTi starting issue when warm (not hot or cold)
    By James24 in forum Engine & Drivetrain
    Last Post: 11th December 2010, 20:28
