Thread: Injectors replacement
    Sep 2010
    Portsmouth
    Default Injectors replacement
    Ive been told by my mechanic that my injectors are all worn and have become a little noisy but are all operating correctly.
    He has said dont rush to replace as a few taxis hes worked on have done 100,000 miles + since having them diagnosed.
    He has also said its the solenoid inside the injector that will be worn, and no amount of injector cleaner or servicing of the injectors will quieten them down?
    Is this true, should i leave these until it becomes affordable?
    Engine : 1.9 CDTi
    He is correct.
    The return springs go weak I think.
    PRESTON
    what type of noise do they make? is it like a tappet out of adjustment noise?
    Regular Member Celes's Avatar
    Slovenia, Koper
    Vehicle : Opel Signum
    Trim : Sport
    Engine : 3.0 CDTI
    Year : 12/03
    They make this noise http://www.youtube.com/watch?v=NRvzAcaK6pA
    She was like new when I replaced her injectors
    Jan 2010
    Scotland
    just leave them if you can, heard some horror stories about injectors not wanting to come out the head at times on the cdti
    Sep 2010
    Portsmouth
    Its almost like a metallic sort of tapping, most noticeable at low revs when the rest of the engine is fairly quiet.
    No performace issues as yet.
    Is it safe to leave these and just turn the stereo up to drown out the noise?
    Have found some bosch ones for the Z19 DTH engine at #90.00 a pop.
    Initially quoted #180.00 each so looking much better.
    Any one had experience of these?
    Engine : 1.9 CDTi
    Take a trip down to Powerdrive as they are great with diesels and will tell you what the noise is. We use them when we have diesel problems at the garage I work at that we cant fix lol.
    Powerdrive
    Unit 7
    Dundas Spur
    PORTSMOUTH
    PO3 5NX
    023 9265 0404
    PRESTON
    Personally, if you have no performance issues, i would leave them for now. I.m sure mine has a couple of noisey ones too, i have a similar tapping on my 1.9 DT and as you said more noticeable at low revs, mine is up to about 1800, then not realy noticable.
  1. injectors
    By damo-SRI-T in forum Petrol Engine related
    Last Post: 9th June 2011, 08:02
  2. Replacement injectors - hard to start?
    By mozzer99 in forum Engine & Drivetrain
    Last Post: 2nd March 2011, 21:04
  3. Replacement injectors bought ££££
    By Celes in forum Vectra C / Signum Car Chat
    Last Post: 22nd August 2009, 00:17
  4. Injectors
    By andymagee1982 in forum Engine & Drivetrain
    Last Post: 8th November 2008, 20:24
  5. new injectors
    By Gr4eme in forum Vectra C / Signum Car Chat
    Last Post: 11th April 2007, 21:52
