Thread: rear wiper arm
    Sep 2009
    Glasgow
    Default rear wiper arm
    On way home tonight wiper stopped halfway, it's only done this once before, when i parked at house, i nudged it and it moved freely, what do you guys think wiper motor on way out.
    Regular Member fingers66's Avatar
    Carpe Diem
    Mines does the same now and then, could be a dodgy controller.
    Sep 2009
    Glasgow
    how does it attach is it bolted on with the plastic cover on top
    Regular Member Jezzy's Avatar
    S.E
    There are two common causes - I can't remember which one causes which symptoms - it's either a brass earth point that's worn through in the motor housing, or (more likely) the connecting rod under the scuttle has popped off. Either pop it back on and use a cable tie to keep in on, or replace it with this improved design:
    http://cgi.ebay.co.uk/VAUXHALL-VECTR...item2eb0d1c05b
    EDIT: Ignore me - just noticed you're referring to the rear wiper, not the fronts.
    Sep 2009
    Glasgow
    thanks for the info anyway mate.
    Regular Member djr69uk's Avatar
    Midlands
    or it could be the relay which is on the way out... either way check the cheapest thing first lol! failing that - guess who has a spare motor if you need it
    Sep 2009
    Glasgow
    cheers for the info
    Glasgow
    If you have had it running while you have been driving its probably the motor thats burned out.
    Regular Member signumboy's Avatar
    Edinburgh/outskirts
    Engine : 2.0 Ltr Turbo
    Mileage : 38000
    Quote Originally Posted by nokiaman1978 View Post
    Not quite sure of the set up on the vectra but i had the same with my motor and it was the spindle/shaft what ever you want to call it becoming corroded below the rubber seal all i did was prized back the seal put some grease in and hey presto ...try the simple things before you try the complicated ones
  1. Rear wiper
    By gunner3011 in forum Vectra C / Signum Car Chat
    Last Post: 28th August 2013, 15:27
  2. Rear wiper
    By benwalters82 in forum Styling
    Last Post: 11th February 2011, 15:16
  3. Rear wiper cap help?
    By winty234 in forum Vectra C / Signum Car Chat
    Last Post: 28th July 2010, 12:32
  4. Rear wiper
    By T4M in forum Vectra C / Signum Car Chat
    Last Post: 4th January 2008, 14:55
  5. Fitted rear spoiler, rear wiper arm hits it
    By JuzzyD in forum Bodywork & Interior
    Last Post: 9th September 2007, 19:00
