Thread: front end noise
    Aug 2010
    herts
    Question front end noise
    got a weird sound on my vectra c when going over speed humps its coming from drivers side,felt like the engine was gonna drop out also noticed the car has started to pull to the right a speeds of 5mph also weird noise when going over rough roads like there is something rattling any help please.
    Are you VXR Enough
    13 Post(s)
    Engine : 6.0 V8 Thunder
    sounds like you need to replace the front anti roll bar bushes and the droplinks on the front fella
    Regular Member Celes's Avatar
    Slovenia, Koper
    Vehicle : Opel Signum
    Trim : Sport
    Engine : 3.0 CDTI
    Year : 12/03
    Both our Signums are making a weird noise when driving or rough roads...like a weird rattle...
    The 3.0 has new drop links...
    Aug 2010
    herts
    cheers will check them is there any think else it could be.
    Are you VXR Enough
    13 Post(s)
    also look for broken springs common on the vec c
    Slovenia, Koper
    Trim : Sport
    Engine : 3.0 CDTI
    Year : 12/03
    Springs on mine are fine. Checked 6k ago when I got the wishbones rebuilt and the droplinks, rod ends replaced.
    north east
    Anti roll bar bushes. best to change drop links and anti roll bar bushes at the same time just because its easier.
    May 2006
    scotland
    Engine mount or mounts ok?
    Regular Member tash's Avatar
    grimsby
    had this on mine few years back, i did post thread on it, turned out i had a broken spring/coil,something like that,,
  1. Noise From Front
    By spennny in forum Suspension, Wheels & Brakes
    Last Post: 6th October 2012, 14:06
  2. Replies: 3
    Last Post: 8th September 2012, 12:13
  3. noise from front end
    By micks edition 100 in forum Vectra C / Signum Car Chat
    Last Post: 8th April 2011, 20:34
  4. OS/Front noise
    By clightowler in forum Suspension, Wheels & Brakes
    Last Post: 1st February 2010, 19:00
  5. 1 noise solved (front Bearing) + 1 new noise (squeaking front brakes!!!)
    By joseantoniovalle in forum Suspension, Wheels & Brakes
    Last Post: 30th September 2006, 08:54
https:www.vectra-c.comforumshowthread.php121265-front-end-noise
