Thread: anyone ever........................
    Regular Member Dan.'s Avatar
    milton keynes
    Default anyone ever........................
    put a cone filter inside there airbox? can it be done?
    WGAF#5
    ive seen Mock ups and tests on other forums for the VXR but not for the
    GSI - MAF 3.2 seemed to suffer on rolling roads and was advised to remove his as he actually lost power over a standard filter setup but his was not an enclosed system . its got to be worth a try as it would help prevent heatsoak
    Regular Member azz man's Avatar
    manchster
    I am also interested in this
    VIP-Member GSiFan's Avatar
    Houghton Regis, Bedfordshire
    16 Post(s)
    Vehicle : Vectra GSi 3.2 V6
    Trim : GSi
    Engine : Z32SE
    Mileage : 212,060
    Why would you do this, though? You don't get the sound because you've enclosed the filter. The surface area of the filter would not be much more than the panel filter, assuming that the airbox mod has been done. At least, I would have thought not. So what would the gain be, apart from a cleanable filter element?
    Not criticising. Just curious.
    Paul
    2003 Vauxhall Vectra GSi 3.2 V6
    Regular Member bangty 1's Avatar
    Sep 2010
    in a box
    to keep it cool eg heat soak
    VIP-Member Das's Avatar
    Turdsville
    39 Post(s)
    Vehicle : Lada
    Trim : Riva
    Engine : 6.0 V12
    Year : 1954
    Mileage : 567890987
    Sorry I dont think heat Soak is as big a problem as most people make out. Ive had a cone filter on my last 3 cars, all have been open systems and all felt much better with the Cone on. Heat soak will really only happen when your at standstill for a length of time, when your on the move its not, IMO, an issue.
    Sep 2010
    in a box
    i dono i got a diesel so no need for open cone
    north east
    Not sure but wouldnt the surface area be reduced as well ?
    it wont be any hotter or colder than haveing a panel filter though so cant see the advantage.
    Regular Member rushy's Avatar
    Vehicle : SRi
    Engine : Z22SE (2.2 Petrol)
    Mileage : 137000
    No real advantage TBH over a panel filter made of the same materials. Open cone filters are a big no no on modern Ecotec's, however not a problem on the old C20's. You only really notice the difference when you go back to stock after a cone as the placebo affect of the noise always makes you think its better. As soon as you go back to a panel the difference is very noticeable. Been there, done that and got the T shirt as they say.
    Full Member paul.sessions's Avatar
    leighton buzzard
    yep i got the t shirt too was rubbish on my diesel..
