Thread: Handbrake making loud plastic/creaking noise
    Regular Member marky2027's Avatar
    Northumberland
    Default Handbrake making loud plastic/creaking noise
    Over the past few weeks the handbrake has been making a loud creaking noise when applied. It's almost like the sound of too much tension in a spring and the noise seems to be coming from just under the plastic cover. It has made this noise in the past but not all the time. It has been much worse since it had a new brake pipe fitted to get though it's MOT. Think it was the rear pipe so could it have been something the garage has done?? What the hell is that noise all about??
    Regular Member Dazzy2006's Avatar
    Notts
    usually its the self adjuster slipping and the cure is to replace the whole handbrake assembly as they dont sell the adjuster seperately.
    If the adjuster has gone the handbrake assembly costs around £130 but to fit it you have to drop the whole exhaust from the cat back
    Northumberland
    How much!! Do you think it might have been something the garage have done?? Is the handbrake in danger of failing if left like this??
    Notts
    mines been doing it for months - do you find your handbrake lever occasionally comes up higher than usual?
    Northumberland
    Yes at times. Just been searching on here and it seems the handbrake cable may be at its maximum adjustment and needs tightening. Might ask a good mate who's a mechanic to look at it. Also read that if you pump the brake pedal couiple of times with engine running and then pull handbrake on few times very hard this can also sort it. Gonna try this in morning.
    Notts
    Quote Originally Posted by marky2027 View Post
    The handbrake cable could have stretched but isnt adjustable so you could try replacing that but best bet is get it checked by a mechanic and go from there
    Northumberland
    Tried the old pumping of brake and yanking of handbrake this morning. Has made no difference
    north east
    Dont push the button on when you lift the hand brake after applying the foot brake ;-)
    Regular Member Exclusive BV's Avatar
    West Midlands
    Quote Originally Posted by Dazzy2006 View Post
    Mine has been doing this for a month now. Makes no noise though.
    It can be normal one time, then next time it will pull up really high, then next time goes back to normal again.
    Been told it might be a sticky brake piston.
    north east
    Engine running.
    Pump brake pedal 5 / 6 times.
    lift hand brake handle with out pushing the button
    release hand brake
    lift hand brake with out pushing the button.
    job done.
  1. Loud creaking noise from servo area ?
    By simac in forum Suspension, Wheels & Brakes
    Last Post: 6th December 2015, 02:35
  2. egr making a buzzing noise
    By wbm156 in forum Vectra C / Signum Car Chat
    Last Post: 24th March 2011, 21:46
  3. Very loud creaking noise from front suspension
    By ROCKATANSKY in forum Vectra C / Signum Car Chat
    Last Post: 9th January 2011, 22:20
  4. CD Player making loud noises and taking ages to play CD
    By baz_rochdale in forum Electrical & ICE (including SatNav)
    Last Post: 10th September 2009, 17:00
  5. Loud creaking from front of car
    By mike12 in forum Vectra C / Signum Car Chat
    Last Post: 10th December 2008, 23:49
handbrake making noise
vectra c handbrake noise
why is handbrake making noise
handbrake noise
Audi A3 loud noise from handbrake
c max handbrake creaks
