Thread: NO Aircon, heater fan, Heated rear Window, Cigarette lighter
    Oct 2010
    manchester
    Default NO Aircon, heater fan, Heated rear Window, Cigarette lighter
    Help ! got a 2007 vectra 1.9cdti 150bhp. the heater fan, Aircon and heated rear window, and cigarette lighter don't work(totally dead). Any help/fixes would be appreciated. Thanks
    Regular Member markj23's Avatar
    Aug 2010
    Luton
    they are on different fuses have you checked the fuses? passenger door open side of dash near a post
    Oct 2010
    manchester
    All the fuses look ok, could it be a relay?
    stockport
    Arrow
    Quote Originally Posted by markj23 View Post
    I had a similar problem not so long ago.With my problem,I lost the radio as well.Sometimes,there was also this short buzzing sound coming from around the computer screen area when I turned the ignition on.
    Well,after a long elimination process it was the 40 amp fuse in the end of the dash.It hadn't blown but was just a poor fit.
    I exchanged it with the one in the boot fuse box and the problem was sorted.
    Hope this helps.FELIXX.
    stockport
    Arrow
    Quote Originally Posted by felixx View Post
    By the way I forgot to add,that the buzzing noise was coming from the blue relay,which is opposite to the 40 amp fuse on the other side of the fuse box.(You remove the glove box to access this area).FELIXX,
    Oct 2010
    manchester
    Ok I'll give this a try. Thanks a lot
    Aug 2012
    Larkhall
    ataylor did you get this problem fixed as i have the same problem just now?
  1. For Sale: Rear cigarette lighter & steering angle sensor
    By pszczo in forum Parts for sale
    Last Post: 30th October 2012, 07:05
  2. No heater a/c heated rear window
    By samuel in forum Electrical & ICE (including SatNav)
    Last Post: 1st November 2009, 16:27
  3. Rear Cigarette Lighter - Power Supply - Help !
    By mickyd98 in forum Electrical & ICE (including SatNav)
    Last Post: 2nd August 2008, 17:22
does the aircon on vectra c use electric heater blower
