Thread: 1.9 CDTI 150 "spanner light"
    Oct 2009
    norfolk
    Default 1.9 CDTI 150 "spanner light"
    Hi there i was hopin you guys might be able to shed some light on this one.
    the history - I have had my vectra for two years and have experienced most of the common faults, induction manifold replaced (worn swirl valves), EGR valve replaced subsequently cleaned, Performed the field mod to number 3 injector and all has been good for a while, although i think the DMF is on its way out, it making some funny noises now when the clutch is held in.
    however i have increasing noticed that when starting first time after the car has been left for some time i get the "spanner light come on", for about 2minutes then it goes off, and does not come back. If i stopped the engine and restart it doesnt come back (this is with out fail did it 10 time before realising that after driving the car for a short time it goes of anyway)
    And some times it doesnt come on atall take this morninf it was really cold and no light , yet when i left work tonight it was on??? (im thinking glowplugs but then this morning discarded that theory!
    any ideas?
    I have a fault code reader religiously plug it in and no fault codes are logged? tried clearing the memory anyway
    Also noticed that the cruise control is dropping out more frequently it can be fine for miles and then touch acceleration button and it cuts out, my gut feel is that this is to do with the DMF ??
    Any help would be appreciated because i dont know if im making things worse every day i drive it
    Regular Member Dazzy2006's Avatar
    Notts
    duff glowplug or relay
    Oct 2009
    norfolk
    Is there an easy way to find out which one it is? can they be metered out?
    the bit i dont get is that i would havethoughtit would log a fault code?
    Bristol
    Vehicle : CDTI 150
    Could be a faulty clutch switch or spring, if this goes you will get the spanner and it may explain why your cruise control is dropping out. Mind you it also normally logs a DTC!!
    Oct 2009
    norfolk
    Quote Originally Posted by Dazzy2006 View Post
    hi ther found the glowplug plug was not fully home, it was loose sitting on top thanks again for your help
    Gareth
    Regular Member skip85's Avatar
    Wiltshire
    Vehicle : vectra c estate
    Engine : 1.9 cdti 150
    Mileage : 150000
    My cruise control drops out and fails to pick up again, other times it can go miles and miles without cliocking off. What are you saying it is and what is DMF? I am new to forum!! Sorry!
    Bristol
    Vehicle : CDTI 150
    DMF is dual mass flywheel, 5hrs to change and £400.
    The clutch spring is part of the clutch pedal costs about £8 and takes about 20 mins.
    Quote Originally Posted by skip85 View Post
    Start a new thread mate, best place for decent answers.
    DMF = dual mass flywheel.
    Full Member
    Jun 2007
    N/A
    Vehicle : Golf 7
    Trim : GTD
    Engine : 2.0 TDI 184PS
    Mileage : 40000
    Could be the brake switch is requiring calibration. My cruise control was faulty unti lI has the switch recalibrated - works perfectly.
    On another note how does the car drive? This could be an early indication of the throttle position sensor circuit developing and 'Open circuit'. I say 'could be' as your profile indicates the car is '04.
    Gazza4
    stockport
    Arrow
    Sounds like it could be the CIM unit.I had a very similar problem,with the offending unit being replaced under warranty,but the cost was quite daunting,and will make your wallet very lighter if it is this problem.FELIXX.
  1. "Winter" Wheels ? Are 19" Snowies best for the "Summer" ?
    By Woody in forum Vectra C / Signum Car Chat
    Last Post: 5th October 2012, 18:43
  2. "Handbrake" Light coming on (54 Plate facelift)
    By dunc2610 in forum Suspension, Wheels & Brakes
    Last Post: 12th August 2012, 19:06
  3. "Spanner Light"
    By elkesprint in forum Engine & Drivetrain
    Last Post: 23rd January 2010, 13:08
  4. Spanner light on dash - "self test"
    By 24vElite in forum Engine & Drivetrain
    Last Post: 23rd March 2008, 20:21
  5. The "flashing car picture with spanner through it" light
    By Big Dave in forum Engine & Drivetrain
    Last Post: 9th February 2008, 04:33
