Results 1 to 10 of 18
Thread: rear bushes
    Jan 2010
    northamptonshire
    Default rear bushes
    hi fairly new to this got a vectra elite rear bushes would that cause a mot failure
    cheers andy
    Regular Member Jezzy's Avatar
    S.E
    There are several bushes at each corner of the car - the ones that fail the most commonly at the rear are one or both bushes in the rear upper control arm (large, banana shaped metal bar with a rubber bush at each end). The whole bar/arm has to be changed, rather than just the rubber bush. Alternatively, the rear anti-roll bar bushes can deteriorate, but that's less likely to cause an MOT failure.
    With the car on the ground, hold the top of the rear tyre and see if the wheel rocks in and out. If it does, seems like the control arm bushes have failed.
    Oct 2010
    cumbria
    the upper control arm large, banana shaped metal bar with a rubber bush at each end. The rubber bush can be changed by pressing a new bush in rather than buying a new arm
    S.E
    Quote Originally Posted by jimmy495 View Post
    The bush can't be changed on it's own fella - maybe you're thinking of a Vectra-B instead.
    Oct 2010
    cumbria
    hi jezzy i have got a 52 plate vectra SXI 1st of the new shape i have changed the top ones on mine going 2 change the bottom ones today. they just press out will try and get the part number for you later mate
    Forfar, Scotland
    Trim : LE/VXR
    Engine : 2.0 cdti/1.6 Turbo
    Year : 13/07
    How much were the bushes?
    Oct 2010
    cumbria
    just got a price for the bush £19.75 inc vat.X 2= £39.50 a side.
    but a new arm is £31.95 how mad is that
    Forfar, Scotland
    Trim : LE/VXR
    Year : 13/07
    Thats why the whole arm is normally changed
    Oct 2010
    cumbria
    i am just going to get to more bushes as i have just put two new ones in sods law if i get a new arm it works out at =£50.75 a arm
    S.E
    Have you got the part numbers (or a link) for just the bush?
  1. For Sale: Rear UCA Bushes x 2
    By neill in forum Parts for sale
    Last Post: 17th December 2012, 19:57
  2. Rear arb bushes
    By tomo610 in forum Suspension, Wheels & Brakes
    Last Post: 18th February 2012, 20:57
  3. rear bushes
    Last Post: 12th November 2009, 22:56
  4. rear bushes
    By north in forum Suspension, Wheels & Brakes
    Last Post: 21st August 2007, 18:14
  5. rear bushes
    By taxea in forum Suspension, Wheels & Brakes
    Last Post: 21st December 2005, 16:06
