Thread: It's that time of year again! Who is having problems with the cruise control again?
    Regular Member Chocki's Avatar
    Jul 2006
    Wolverhampton
    Default It's that time of year again! Who is having problems with the cruise control again?
    Every winter it's the same, the cruise control goes on the blink!, now it could be due to warm moist air from the vents condensing inside the cold stalk where it blows over it, or my guess is that the resistance goes out of range!, if you check the stalk resistances, you will find that it detects the state of the buttons by using just two wires and by switching a different resistance across the two wires, so my guess is that the resistance is changing ever so slightly with temperature and this is what is causing the cruise control to drop out.
    What's the fix?, I don't know, maybe new models have slightly different software, or resistance tolerances, are they prone to this failure at all?.
    Anyone with any other ideas apart from those that just have loads of dirt inside the switches.
    Full Member GazVXLINE170's Avatar
    Jun 2007
    Scotland
    Vehicle : Insignia
    Trim : SRI VX-Line Nav
    Engine : 2.0 CDTI [170 PS]
    Year : 2015
    Mileage : 27000
    May need the brake pedal/light switch re-calibrated. It sorted mine out.
    Gazza4
    Insignia VX-Line Nav CDTI 170.
    Jul 2006
    Wolverhampton
    Not the pedal switches as I've checked their operation using software, but good point.
    Huddersfield
    No issues with mine.
    Oct 2010
    northampton
    no probs with this just probs with the lower comp button on the opposite stalk
    Sep 2009
    Audley STAFFS
    the odd time mine has not come on I just tap the clutch pedal and it works ok.
    Sodding Typical on Sea
    I found mine went on the blink on my run down to Bolton (after I refuelled at Southwait £1.339 per litre!!!! Never again)
    I returned to the m'way and no cruise. I returned next day however and was my OWN stupid fault as I didn't remeber the press the brake once engagement rule.
  1. update on cruise control problems
    By deano1 in forum Electrical & ICE (including SatNav)
    Last Post: 16th October 2012, 13:30
  2. Cruise control problems
    By johnny kebab in forum Troubleshooting
    Last Post: 24th January 2012, 11:49
  3. Cruise Control Problems
    By R-ford_Vec_C in forum Electrical & ICE (including SatNav)
    Last Post: 13th August 2011, 23:33
  4. Cruise Control problems again
    By Thom in forum Electrical & ICE (including SatNav)
    Last Post: 16th June 2011, 00:07
  5. cruise control problems!!
    By dannydm1 in forum Electrical & ICE (including SatNav)
    Last Post: 8th April 2009, 14:05
