Originally Posted by
the-wizard
Hi dek, I've been following & commenting on most 'vent to atmos' threads so knew this was the answer but, I think we could do without an oil catch can because!, If like me & I think most others, you are getting nothing out of your atmos vent, it proves that there's To much suction from the inlet SO, Why not reduce this somehow, if we could find out roughly how to do this ie a reducer or such, there would be enough suction to draw the fumes ( about the same as it naturally vents with atmos vent), Therefore there's enough to let it breath but not to much to suck the oil out.(that's what's happening now with atmos vent!). I have no oil coming out of the atmos vent so why cant it be drawn away via the inlet as it was before but slower!. what do you think?, it would be a lot less ugly to look at & would hardly be noticeable if at all. I do believe there's a simple fix to this & using what we already have but manipulating it slightly!, if i vent through some catch can there will be no oil in it as im getting none anyway.
