Results 1 to 10 of 11
Thread: Power Steering Failure
    Regular Member gsi.vxr's Avatar
    Hertfordshire
    Default Power Steering Failure
    Power steering failed on my GSi the other day. Been told it may be the alternator; £189 from Vauxhall. And also been told it may be the PAS pump. £687 from Vauxhall. Ouch. Help! Anyone know what the most common fault is on these? And if so anywhere I can get cheaper parts?
    Thanks guys and girls.
    Aug 2010
    Antrim
    Is your battery charging? If all else on the electrics are ok, I would imagine it is not the alternator.
    Hertfordshire
    Battery seems to be charging. No warning lights for alternator so I'm worrying it's the pump.
    Aug 2010
    Antrim
    If you have a voltmeter (multimeter) you can check the alternator easily enough. Sad to say I would say that it is much more likely to be the pump. Power Steering cars do need a bigger alternator than the same car without, but I would imagine a failure in the alternator would show up as multiple electrical problems.
    Full Member Big-Pete's Avatar
    May 2007
    Home or in the Gym
    96 Post(s)
    Vehicle : Audi Q7
    Trim : S-Line Plus 245
    Engine : 3.0 TDV6
    Mileage : 3023
    Moved to a more relevant section for you
    General Chat Any non-car related chat
    Hertfordshire
    Quote Originally Posted by Big-Pete View Post
    Thank you.
    Bump!
    Regular Member Dazzy2006's Avatar
    Notts
    Start the car, using a multimeter check what voltage is at the battery - if it reads 13-14 volts your alternator is fine.
    If you suspect the pump has had it cant you get one from ebay or breakers yard, got to be alot cheaper than main dealers.
    Hertfordshire
    Yea, had battery and alternator checked, they're fine. Been looking into aftermarket pumps, found somewhere that can help but they need to know if it's a Saginaw or TRW pump? How do I find that out? Cheers.
    Notts
    Hertfordshire
    Quote Originally Posted by Dazzy2006 View Post
    Nice one. Thanks. Is there not two options then I guess?
  1. power steering failure?
    Last Post: 20th April 2012, 16:38
  2. Power Steering Failure
    By derrybulmers in forum Suspension, Wheels & Brakes
    Last Post: 9th August 2011, 20:10
  3. Power steering failure
    By Chris06v6 in forum Engine & Drivetrain
    Last Post: 28th July 2011, 06:22
  4. Power steering failure???
    By PeterVV in forum Vectra C / Signum Troubleshooting
    Last Post: 7th October 2010, 06:37
  5. Power steering failure
    By Bobfish in forum Vectra C / Signum Troubleshooting
    Last Post: 23rd August 2008, 19:59
