Results 1 to 3 of 3
Thread: miss-fire on vec c 1.9cdti 150bhp
    Aug 2010
    south northamptonshire
    confused miss-fire on vec c 1.9cdti 150bhp
    hi guys from yesturday my car has started miss-firing when at tick over and when driving. has anyone had this issue before do you think it could be glow plugs? many thanks
    Bristol
    Vehicle : CDTI 150
    Very unlikely to be glow plugs as they are only used to assist starting.
    Have you had the 3rd cylinder injector plug sorted??
    Lift the engine cover if the 4 plugs that power the inj all have yellow clips then it may need doing, modified plugs have blue clips.
    To check disconnect plug, clean plug and socket with a bit of WD40 allow to dry and refit If problem goes away then it will need the plug replacing.
    New plug costs less than £15 from Vx, however you do need to use a soldering iron to replace.
    If you do a search for 3rd inj fault you will get a lot of gen
    Aug 2010
    cheers mate thankyou i will go look how.
  1. 1.9CDTI (120) Hesitating / Miss Fire
    By pshankland in forum Engine & Drivetrain
    Last Post: 20th June 2012, 12:50
  2. Miss-fire, judder, low tick over????
    By Mattle40 in forum Engine & Drivetrain
    Last Post: 14th February 2012, 14:46
  3. vec b miss fire
    By daddyjay in forum Engine & Drivetrain
    Last Post: 25th September 2011, 19:26
  4. loss of power miss fire
    By basemanlee in forum Vectra C / Signum Car Chat
    Last Post: 6th April 2010, 20:41
  5. Miss Fire has gone!
    By Maverick in forum Diesel Engine related
    Last Post: 12th June 2009, 09:02
