Thread: LPG Vectra C 2003 1.8
    tebay,cumbria
    Default LPG Vectra C 2003 1.8
    Hi,
    I have a missfire when using LPG,runs fine on petrol.
    Any ideas?
    Regards
    Dave
    Huddersfield
    LPG injector (or whatever there called). Try a specialist and they should easily diagnose it. There are that many different systems it would be hard to guess on here.
    May 2008
    Tyneside
    Is it factory fitted or a conversion? Need to get a diagnostics done at specialist on your particular system. What system have you got? Could be just a filter change required.
    Dec 2012
    north wales
    Vehicle : vectra
    Trim : estate life / gas
    Engine : 1.8xer
    Mileage : 184000
    b4 u change anything check the compression's i had similar fault found out 3 valves cracked wont cost anything to check it
    Leicestershire
    Trim : PreFace SRi
    Engine : 1.8 LPG
    Year : 53
    on mine i had 2 blocked injectors on my factory fit one. couldnt source parts as they are obsolete now. found a good company on eBay, drove down to his garage and he put in 4 new patent part injectors in for me. he makes the injectors himself, and fine tunes the injectors to your needs. my other option after visiting many different specialists was to install a complete brand new system. i didn't want this as it involved removing the old system altogether and having other displays and switches mounted on/near my dashboard.
    if yours is switching over to gas fine then it sounds like to me you have just a blocked filter which is fairly easy n cheap to replace.
  1. Hello All! I am new Vectra C 2003 SRI 2.2 DTI
    By congaman in forum Introduce yourself.
    Last Post: 2nd October 2010, 11:20
  2. Vectra GSI 2003
    By icie69 in forum Vectra C / Signum Car Chat
    Last Post: 22nd February 2010, 22:09
  3. Vectra Sri 2003 90k
    By Gregg in forum How much is it worth? (THIS SECTION IS NOW CLOSED)
    Last Post: 3rd March 2009, 17:07
  4. 2003 Vectra 2.2 sri
    By speedo in forum Cars for sale
    Last Post: 31st December 2007, 11:33
