Results 1 to 3 of 3
Thread: Power for tow sockets?
    Oct 2010
    Lincoln
    Default Power for tow sockets?
    Anyone know an easy place to pick up the 12V feed for the 7 way relay and the split voltage relay for towing sockets? My old Vectra B had a nice big wire already in place in the boot.
    Full Member kenp's Avatar
    Kr. Hyllinge, Denmark
    Engine : 2.2 Direct
    put in OEM towbar wiring and towbar module.. then its easy..
    but the large fuses in the back (or where theres room for them) is ready for 30 amp fuses.
    Oct 2010
    Lincoln
    Problem is that this car has had a towbar on it at sometime but typically when it was taken off they simply cut the wiring and left it stuck up behind the bumper and I have no idea what the wiring is. Looks like it is terminated in the rear fuse box, one large grey wire and one large black one. I suppose I could pull it back into the boot and try to figure out the wiring with a meter but it's probably going to quicker/easier to simply scotch lock onto the rear light cluster. As I'm using a bypass relay I just need a 12V feed to the relay and the split charge relay for the fridge/battery.
  1. Lost power from 12v sockets..
    By Steven in forum Electrical & ICE (including SatNav)
    Last Post: 21st December 2012, 00:06
  2. alternative power feed to 12v sockets
    By Vecmaniac in forum Electrical & ICE (including SatNav)
    Last Post: 22nd January 2012, 19:08
  3. parking sensors and power sockets stopped working
    By charliepirate in forum Electrical & ICE (including SatNav)
    Last Post: 29th July 2010, 13:37
  4. Flipping 12v sockets
    By RobW in forum Vectra C / Signum Car Chat
    Last Post: 14th May 2010, 16:19
  5. Power sockets and heater
    By badback in forum Electrical & ICE (including SatNav)
    Last Post: 25th September 2009, 15:49
