Thread: Heater Blower and Reostat
    New Member monks's Avatar
    Oct 2010
    Oxford
    Default Heater Blower and Reostat
    Hi All,
    Right here`s my delama...
    I had water coming in through via pollen filter (leaves blocked the drain under scuttle panel) which damaged blower motor so have since replaced blower motor unit but this would only work on num 4 so have since changed reostsat and still the same outcome - I noticed that with 2nd reostat that fan was slightly working on its own accord even when switch was on off position and that the reostat was heating up is this normal as old reostat stayed cool...?
    Both reostats only seem to work on num 4 but not on either 1,2 or 3.
    The relay clicks only when fan is put on num 4 so could it be the relay needs replacing and not the reostat...?
    My car is an 03 model and the parts i got to replace are blower motor from a 52 plate and reostat from a 05 plate both parts are from a reliable salvage merchants.
    Oct 2010
    south yorkshire
    I have exactly the same symptom, only blows on number 4, would like to know what the problem is too.
    VIP-Member superstuper's Avatar
    Trieste, Italy
    Vehicle : Opel Vectra C
    Trim : Estate F35, Elegance
    Engine : Y22DTR
    Oct 2010
    south yorkshire
    yeah I was just trying to find this post to add those links again, very extensive thread
    Trieste, Italy
    Engine : Y22DTR
  1. Heater / Blower Fan
    By chris2464 in forum Bodywork & Interior
    Last Post: 5th January 2012, 13:30
  2. heater blower
    By bootneck85 in forum Electrical & ICE (including SatNav)
    Last Post: 18th April 2011, 00:40
  3. Heater blower!!!!!
    By mitch in forum Electrical & ICE (including SatNav)
    Last Post: 19th November 2010, 00:15
  4. heater blower
    By Pete Kincaid in forum Vectra C / Signum Car Chat
    Last Post: 11th January 2010, 21:58
  5. Heater Blower
    By Woolly in forum Electrical & ICE (including SatNav)
    Last Post: 26th July 2008, 18:12
