Thread: Radio Codes
    Nottingham England
    Default Radio Codes
    Apologies if this isn't the right area as this is my first thread.
    I have just had to buy a new battery for my 2001 Vectra diesel and my radio is locked.
    Can anyone tell me (a) how do I get the radio out without having to buy keys, (b) where would i find the unlock code so that I can use my radio again. My radio is a Delco CDR500. Thanks in advance
    Regular Member LADmachining's Avatar
    Hampshire
    The radio code should be with the vehicle handbook pack, and is either on a red card with 'radio pass' on it, or on the grey 'car pass' card under 'radio code'.
    If don't have either of these cards, then you can go to Vauxhall and order a new car pass (which you will also need if you want to program any new keys to the cars immobiliser), which costs about £20. Be aware that the radio code they provide will only be the one for when the car was new. If the radio has been changed in the past, then the code will be different. You need to supply the serial number off the side of the radio to ensure you get the right code back from Vauxhall.
    The radio can be removed by using a couple of bits of coathanger bent into a U shape to fit into the two holes on each side of the radio. The proper keys are available from Halfords or most auto factors for a couple of pounds, and are much easier to use.
    Jul 2009
    The Rift, Cardiff
    If you dont have the CarPass it might be worth contacting the previous owner to see if they have it, could save £20, didn't work for me though I had to pay £23. Maybe also worth seeing if its been written on the stereo as it was on my sisters astra.
    Oct 2010
    Lincoln
    I used a guy on Ebay to recover the code. Seems it's based on the long serial number on the radio. He emailed it to me within a few hours and it worked fine.
    Oct 2010
    Lincoln
    Try this one if your radio is listed --
    http://cgi.ebay.co.uk/Vauxhall-Radio...item5889f7f3a4
  1. radio codes
    By tyler boy in forum Electrical & ICE (including SatNav)
    Last Post: 22nd September 2011, 19:56
  2. Radio codes
    By Munch85 in forum Electrical & ICE (including SatNav)
    Last Post: 12th August 2011, 18:24
  3. Radio codes
    By Gortreck in forum The 'Off Topic' room
    Last Post: 1st February 2010, 14:09
  4. radio codes .............
    By carl30 in forum Electrical & ICE (including SatNav)
    Last Post: 3rd January 2008, 19:10
  5. Radio Codes
    By Ste in forum Vectra C / Signum Car Chat
    Last Post: 23rd November 2007, 17:25
