Thread: knocking noise from rear wheels
    Oct 2010
    N. Ireland
    Default knocking noise from rear wheels
    I have a slight knocking noise from rear wheels on both sides when driving on uneven roads, and theres a lot of uneven roads here.
    I looked at the drop links and the anti roll bar bushes and they look ok.
    It could be the upper control arms, is there any way of checking this.
    Car has almost 80k miles.
    Forfar, Scotland
    Trim : LE/VXR
    Engine : 2.0 cdti/1.6 Turbo
    Year : 13/07
    Although the ARB bushes look ok don't rule them out, the slightest bit of wear and they will knock.
    To check the UCA's, with the car on the ground grab the top of the road wheel and sharply tug it. If they are knackered you'll hear (and feel) them knocking
    Oct 2010
    N. Ireland
    Thanks for your reply, John.
    I done as you explained today, doesnt seem to be any movement there. Im sure it will become obvious soon enough, where the problem part is.
    Jul 2010
    Waterford, Ireland
    I have that knocking noise too. Replaced ARB bushes but the noise is still there. Very annoying! Also have a fault showing for headlights even though they're fine. Disconnected battery and ecu but fault still showing. Any ideas?
    Oct 2010
    N. Ireland
    Quote Originally Posted by darrensten View Post
    Hi Darren,
    Did you replace the drop links too? Did you check the UCA's for movement as suggested by others.
    I've done nothing to mine yet, I know its not serious just a bit annoying as you said.
    I mite disconnect the drop links on each side tempararly and take it for a short run, If the knock has gone then its either the drop links or ARB bushes and will change the lot.
    If the noise is still there then its something else, probably UCA's startin to go. That what I think.
    I wouldn't have any ideas about the headlights, but if you start another thread I'm sure someone will help.
    Jul 2010
    Waterford, Ireland
    Turns out it was the shocks all along. Parts man in main dealer said they wear on the inside with no visible defects, he said it was fairly common. Got spurious shocks €70 each.
  1. Knocking noise from rear
    By IrishVectra in forum Suspension, Wheels & Brakes
    Last Post: 8th October 2012, 20:40
  2. knocking noise from rear
    By Lozza in forum Suspension, Wheels & Brakes
    Last Post: 1st May 2012, 18:35
  3. knocking noise at rear
    By skidmark1 in forum Vectra C / Signum Car Chat
    Last Post: 14th February 2011, 20:54
  4. Knocking noise from rear
    By PeterVV in forum Vectra C / Signum Car Chat
    Last Post: 3rd October 2010, 20:36
  5. knocking noise at rear.
    By piker john in forum Suspension, Wheels & Brakes
    Last Post: 4th July 2010, 17:39
