Results 1 to 10 of 11
Thread: Safeguard Message
    Oct 2010
    Derby
    Default Safeguard Message
    Evening chaps.
    Just a quick one. Picked up my new motor on Friday, loving it!
    When you turn the radio/cd player, a message comes up saying 'safeguard'. Everything works fine, and the message goes away when you press a couple of buttons to reveal the track name etc.
    is this a fault or something I should be worried about?
    Any help much appreciated
    Regards
    TC
    Regular Member husky's Avatar
    Edwinstowe
    Trim : VXR-D
    Engine : 1,9 CDTi 150
    yes its telling you there is a problem with the alarm ultrasonics , i had the same fault when i removed my interior light assy
    Oct 2010
    Derby
    Thanks for the quick reply husky... is it worth taking it back to the garage?
    Regular Member dansri's Avatar
    Jul 2010
    doncaster
    ive got this and its doin my nut in.
    Oct 2010
    Derby
    The stereo works fine though!, just a bit annoying to have every time you get in. Once you press the rocker buttons, it goes away and the track info comes on...
    Jul 2009
    The Rift, Cardiff
    It means there is a problem with the alarm system, which possibly invalidates your insurance. Take it back and get them to fix it. It could be something simple like a loose ultra-sonic connection behind the interior light or something expensive like the battery in the siren box.
    Regular Member 3.2_V6_VXR's Avatar
    S.Wales, Nr Swansea
    I had this problem on my old Gsi, it turned out to be the back up battery was on its last legs in the alarm siren mounted in the boot, I bought a second hand siren from ebay and it never done it after that
    swansea
    The alarm siren may be disconnected, enabling the horn, which is louder.
    Hull
    I had this problem, garage tried fixing it to no avail, so I started checking fuses, there's a safeguard fuse in the boot I think, took it out, put it back in, and the message never came back. Dunno if it's any use
    Regular Member Dazzy2006's Avatar
    Notts
    I also had this problem and it turned out to be the rear heated screen had breaks in the wire - if your rear heated screen doesnt work it will probably be down to that
  1. check safeguard message fault, and computer screen staying on, what can it be?
    By taffy bhoy in forum Electrical & ICE (including SatNav)
    Last Post: 4th October 2012, 17:44
  2. Help safeguard message beig displayed
    By chuckleuk in forum Electrical & ICE (including SatNav)
    Last Post: 14th August 2011, 11:29
  3. Safeguard message and no alarm
    By MORGIE8153 in forum Electrical & ICE (including SatNav)
    Last Post: 26th July 2011, 21:44
  4. "Check Safeguard" Message
    By Loz2286 in forum Vectra C / Signum Troubleshooting
    Last Post: 14th February 2011, 16:47
  5. the check safeguard message
    By dansri in forum Electrical & ICE (including SatNav)
    Last Post: 24th January 2011, 19:15
