Results 1 to 10 of 17
Thread: 2.0 Dti Wont Start After EGR/Manifold Clean
    LONDON
    Default 2.0 Dti Wont Start After EGR/Manifold Clean
    Hi can anyone help. I took out my EGR valve and the the manifold. Cleaned them out put them back, tried starting the car and it just wont start. I checked that all the bolts were on tight and they are. When im turning the engine it sounds odd like theres no fuel coming through, hard to describe. I tried loosening the last fuel pipe, turned it over to see if fuel came out and incase if there was an airlock. Fuel came out but still doesnt start. Would the car not start if ive somehow screwed up the EGR valve??? Can anyone help????
    Vehicle : vectra-c
    Trim : sri
    Engine : cdti
    Mileage : 98,000
    Strange!, try disconnecting the temprature sensor wire/connector, this will force the glow plugs on, it may just give it enough help to start!, if not ????, then go back over & double/double check everything youv'e touched.
    LONDON
    Where abouts is the temprature sensor wire/connector???
    LONDON
    Havent located the sensor yet, but tried turning the engine over again. It sounded like it was almost going to start but didnt. Gave it a minute, turned it over again and it just wouldnt catch, not even a sign, it sounds really odd.
    Regular Member Aikon58's Avatar
    Englandshire
    Vehicle : shatch- sports hatch
    Trim : cheap plastics
    Engine : metal
    Year : 1901
    Mileage : 999
    Make sure the fuel filter is full,crack the top union nuts at each injector while cranking the engine,and i'm sure it will catch,if no luck that way,last resort is easy start in the intake,i.e egr intake.
    And the temp sensor is on the thermostat housing,its the one with a plug on it,not a single connector.
    LONDON
    just filled up the fuel filter, but if i loosen the nuts at all the injectors wouldnt I have to remove the leak off pipes??? How do I loosen them with the leak offs getting in the way???
    Vehicle : vectra-c
    Trim : sri
    Engine : cdti
    Mileage : 98,000
    Quote Originally Posted by chiko48 View Post
    cant remember off hand but it may look like this (ebay).
    http://cgi.ebay.co.uk/Opel-Coolant-T...item3caef4795b
    Englandshire
    Engine : metal
    Year : 1901
    Mileage : 999
    Its been a while since i had to do this,as far as i remember you can un-crack the top union nuts with the leak off pipe in place,just do one at a time until fuel comes through,and lock the nut back up,and move on to the next one.
    Regular Member chris1804's Avatar
    Oct 2009
    Sandwell
    Try this , get somebody to tow you and try and bump start it. Or why you try and start it put your foot on the acc pedal to the floor. I never had this prob tho with my 2.0dti . Is the egr connector connected? I would try a bump start tho
    LONDON
    located the sensor and disconnected it. tried starting it but still no luck.
  1. Replies: 15
    Last Post: 3rd July 2012, 21:14
  2. car wont start? :(
    By ben2996 in forum Vectra C / Signum Troubleshooting
    Last Post: 24th March 2012, 12:30
  3. car wont start!! help!!
    Last Post: 20th January 2011, 15:39
  4. 2.2 SRi wont start
    By karlos007 in forum Vectra C / Signum Troubleshooting
    Last Post: 3rd December 2010, 16:37
  5. Wont start when below 1C
    By turb0z in forum Engine & Drivetrain
    Last Post: 12th January 2008, 16:34
vauxhall zafira dti cleaned the egr now wont start
audi 2.0 tdi wont start after egr
vectra c cleaned manifold not starting
ive cleaned the air manifold on my vauxhall vectra and now the car wont start
cleaned vecta egr car wont start
2l zafira wont start after cleaning egr valve
zafira wont start after egr removal
Cleaned egr valve on vauxhall zafira now car wont start
zafira dti engine will not turn over after cleaning egr valve
vauxhall zafira 2.0 dti inlet manifold cleaning
audi 2.0 tdi had inlet manifold wont start
2.0 dti egr bypass
easystart diesel after egr clean
egr valve vauxhall vectra 2.0 dti
Astra cdti cleaned egr car wont start or crank up
