Results 1 to 3 of 3
Thread: fault codes
    Regular Member trickyjacks.4's Avatar
    nottingham
    Default fault codes
    I've got eml light on my 04 2.2direct sri. I scanned for codes this morning and got p1112 intake air temperature sensor circuit intermitent low voltage. Can anyone shed any light on wether this will just be a new sensor needed or maybe something else.I've also just done the airbox mod and replaced the jubilee clips each side of the maf sensor because they we siezed and loose. Touch wood I haven't seen the eml since.
    Bristol
    Vehicle : CDTI 150
    Possibly a dodgy connector to the MAF, which incorporates the IAT sensor. By disconnecting and reconnecting you may have cured the fault, if it reoccurs try cleaning the connectors before replacing the MAF
    nottingham
    thanks for the advice, done 70 odd miles today and still no eml light.
    thanks again.
  1. fault codes?
    By farley2708 in forum Engine & Drivetrain
    Last Post: 5th February 2012, 00:18
  2. fault codes
    By ADAM123 in forum Engine & Drivetrain
    Last Post: 31st January 2012, 19:02
  3. Fault Codes
    By tony100la in forum Vectra C / Signum Car Chat
    Last Post: 10th November 2010, 09:49
  4. Fault Codes
    By cdms811 in forum Vectra C / Signum Car Chat
    Last Post: 15th November 2007, 14:17
