Results 1 to 10 of 15
Thread: what's a good brake upgrade?
    Sep 2010
    doncaster
    Default what's a good brake upgrade?
    hi all can any one help? iv got a 05plate signum 1.9dtci (150) but iv had it remaped and it runnin at just over 200bhp so i think its time to make it stop abit better can anyone help? what is a good upgrade for the brakes?
    preston
    314mm seems a good upgrade
    i got mine from scrapped V6
    make sure that you get the 292 from the rear at same time so to maintain balance
    make sure V6 is 314model as early ones carried 302mm
    I think neo brothers do a 314mm setup on the web
    others do 345mmVXR setup but that might not fit under 17inch rim or if it does be very close with issues with wheel balance weights
    I have a 302mm front set awaiting a good home if you are interested or can't locate a 314mm set
    pm me if you want them.
    Jul 2006
    Northampton
    Trim : Sri
    Engine : 1.9 cdti 150
    i recently upgraded to 314 front and 292 rear and there is a good difference. well worth it
    Full Member Big Sig's Avatar
    Quote Originally Posted by mparks8590 View Post
    just a note; all of the v6 cdti's (dti's) had 314mm also.
    Regular Member Vectra_C_Chris's Avatar
    Perth Western Australia
    My 2003 CDXi (GSi) had 314mm brakes. I'm still confused at why some V6's have them and some don't. 314mm brakes easily fit 17" wheels. Go for the 345mm VXR discs and get some real stopping power. Won't fit below 19" apparently.
    (Also looks awesome )
    Quote Originally Posted by Vectra_C_Chris View Post
    The 345's will fit under some 17's
    Regular Member simon1's Avatar
    Oct 2007
    Leicester
    Vehicle : Vectra elite
    Engine : 1800
    Mileage : 80000
    as the man says do fit under 17 fitted a set to mine also just got a set of 292mm rears to fit later today been in shed a month now got a week off work will see if any diff in the rear braking
    preston
    yes but also think about if you get a flat
    will they work with spare wheel?
    314 will work with spare
    345 probably won't
    East Scotland Regional Organiser signumboy's Avatar
    Edinburgh/outskirts
    Engine : 2.0 Ltr Turbo
    Mileage : 38000
    345 probably won't
    Easy answer take one of the wheels off the rear & put spare on in place
    Regular Member Jezzy's Avatar
    S.E
    My 2003 CDXi (GSi) had 314mm brakes. I'm still confused at why some V6's have them and some don't. )
    No need to be confused fella - GSi's up to chassis number 31070293 had 302mm front disks; GSi's with chassis number 31070294 onwards had the 314mm disks.
  1. New upgrade ?? Is this any good?
    By Elahi_786 in forum Diesel Engine related
    Last Post: 2nd April 2011, 13:16
  2. 302 mm brake upgrade - any use ?
    By baard in forum Vectra C / Signum Car Chat
    Last Post: 16th April 2009, 22:58
  3. Brake upgrade
    By s1nglef1sh in forum Handling & Braking
    Last Post: 27th October 2008, 23:27
  4. Big Brake Upgrade
    By parapaul in forum Suspension, Wheels & Brakes
    Last Post: 8th January 2007, 20:16
