Thread: Now Im confused?...
    Regular Member bigdave1701's Avatar
    York
    Default Now Im confused?...
    After months of the rear end knocking over uneven ground and speed bumps, I'd diagnosed it (with help from forum members) as the rear upper control arms, ordered the parts and set this weekend aside to do the work.
    mrs bigdave called into the garage run by her dads mate to book the car in for its MOT. While there, he put the car on the ramp to have a quick poke round to make sure there's no other work that needs doing for the MOT and she told him about the repair work I was intending doing this weekend. He had a look and said he cant see anything wrong and in all the years hes worked with Vauxhalls hes never know the rear upper control arms go. Annoyingly emma didnt think to ask what it was thats knocking...
    So what do I do now? Do I go on his advice and do nothing and hope he spots the fault during the MOT. Or do I do the repair anyway as Ive already bought the parts?...
    Mileage : 000
    Peace of mind now you have bought the parts. I don,t know how difficult they are to change. But you never know it might cure the knocking. If it was me and I had bought the parts I would be changing them, as I say peace of mind if nothing else.
    Regular Member Jezzy's Avatar
    S.E
    Quote Originally Posted by bigdave1701 View Post
    ..and in all the years hes worked with Vauxhalls hes never know the rear upper control arms go...
    That just isn't the case - failure of the bushes in the upper rear control arms is very common in the Vec-C. When I replaced mine, one bush in each control arm was like jelly. Either he's referring to some other component, or your wife has mis-relayed his message, or some other confusion has taken place. If you have the spares, use them.
    preston
    if you feel your rear end ( car that is ) flick out slightly when taking a corner at speed, then theres a good chance the arms need replacing, you can always try the wheel grab test.......thats usually a good sign of wear / tear in this area
    Regular Member Das's Avatar
    Yer Maws Bedroom
    40 Post(s)
    Vehicle : Honda Civic
    Engine : 1.8 iVtec
    Mileage : 65500
    Bigdave have you done the test to see if it is the upper control arms that are at fault?
    Oct 2007
    nottingham
    did the same as you,changed my upper control arms knocking was still there.then changed arb bushes noise has gone .
    tommy
    Jul 2009
    The Rift, Cardiff
    I thought the bushes were inside the arm and not visible unless the arm is removed? And i'm sure they have a finite lifespan, being rubber.
    York
    I didnt get time to have a look. By the time I'd finished servicing the car it was hammering it down. Theres always next weekend..
    Nov 2009
    Norfolk
    I take my signum to bloke who used to be a vauxhall workshop manager.
    He put it up on the ramp and diagnosed it.
    Mine is booked in to have them changed, they are known for going.
  1. Confused!!!
    By tammyman09 in forum Electrical & ICE (including SatNav)
    Last Post: 25th February 2011, 15:53
  2. How confused am i
    By 21_03_sxi in forum Vectra C / Signum Car Chat
    Last Post: 12th February 2011, 22:36
  3. Confused???
    By monty2000 in forum Vectra C / Signum Car Chat
    Last Post: 19th February 2010, 11:31
  4. I'm well confused now.
    By shan in forum The 'Off Topic' room
    Last Post: 28th January 2009, 10:12
  5. Confused About Car Key
    By Hynzy in forum Vectra C / Signum Car Chat
    Last Post: 21st January 2009, 22:54
