Thread: silver dash strips
    Sep 2010
    hampshire
    Default silver dash strips
    how do i get the silver dashboard trim off and the same bit on the doors ?, iv had a quick look in the how tos and cant find anything, any help apreciated.
    Regular Member davidlewis24's Avatar
    bridgend / wales
    hi mate i believe they come attached to the plastic strip and come complete i know the dash strip just pulls off hope it heps
    Sunny Dartmoor
    You open the glove box and the dashboard trim just pulls off,the door trims are held on with plastic rivets,you need to chisel them off from behind the trim,hope that helps
    Sep 2010
    hampshire
    thanks for the replys, do the rivets break as you pull them off or will they go back on, im thinkin of wrappin then in vinyl wot do you reckon ???
    Blantyre
    No they shouldnt, there metal spring type clips
    Forfar, Scotland
    Trim : LE/VXR
    Engine : 2.0 cdti/1.6 Turbo
    Year : 13/07
    Quote Originally Posted by vvcsri View Post
    They are plastic rivets and yeah you'll need to use something to hold them back on with. Maybe worth just taking the door card off wrapping them in place
    Blantyre
    Arent they metal spring clips, what part u talking about, is the OP not on about the big silver dash trim that runs along the dash and then the small bit on drivers side ?
    Forfar, Scotland
    Trim : LE/VXR
    Year : 13/07
    He's on about both mate, the dash and the doors
    As said the dash is easy and just un-clips/ clips back on
    Blantyre
    Ah ok, thought he was on only about the dash bits
    Sep 2010
    Dumfries, Scotland
    I vinyl wrapped mine in carbon, didn't like the wood effect!! The dash strips just pull off, the door cars are as others have told you plastic riveted on. I stuck a 13mm drill bit in the drill and took the heads off them. To get them back on youo'll need the correct sizes (diameter and length). I didn't have any so i cut down some rawl plugs and used the screws i had. Looks a lot better now.
    I'd recommend getting them off the door cards though, if you try and wrap them on the card you'll never get a good finish.
  1. chrome strips on dash and doors in a sri??
    By renton608 in forum Bodywork & Interior
    Last Post: 14th January 2011, 18:05
  2. silver strips
    By titley1976 in forum Vectra C / Signum Car Chat
    Last Post: 9th September 2010, 12:41
  3. Dash strip and door card strips
    By Derek Mc in forum Styling
    Last Post: 3rd May 2010, 09:04
  4. Heater vents, clocks and chrome dash strips
    By blues n twos in forum Parts for sale
    Last Post: 9th October 2008, 20:26
  5. SRI silver door strips.
    By rushy in forum Detailing and Car Care Discussion
    Last Post: 6th August 2006, 21:33
opel vectra c dash strips
