New to these fuse boxes in the boot
How do I get at the full fuse box on a 56 plate Vectra?
Daughter has an 05 plate Astra and she has a large panel to remove so the fuse box is fully visible. All I've got is a small panel which shows part of it?
is it a estate? because then you can remove the molding to.. (dont know how the hatch/saloon look like)
but probaly the same, just removes.
If its a hatch, remove the trim at the rear of the boot, remove part of the rubber seal, remove the little popper just below the speaker shelf, remove the boot carpet and it just pulls out from the bottom
Many thanks, it's a hatch so I'll have alook 2moz
