Thread: Fuse box access
    Oct 2010
    Lincoln
    Default Fuse box access
    New to these fuse boxes in the boot
    How do I get at the full fuse box on a 56 plate Vectra?
    Daughter has an 05 plate Astra and she has a large panel to remove so the fuse box is fully visible. All I've got is a small panel which shows part of it?
    Full Member kenp's Avatar
    Kr. Hyllinge, Denmark
    Engine : 2.2 Direct
    is it a estate? because then you can remove the molding to.. (dont know how the hatch/saloon look like)
    but probaly the same, just removes.
    Forum Moderator John LE's Avatar
    Forfar, Scotland
    Trim : LE/VXR
    Engine : 2.0 cdti/1.6 Turbo
    Year : 13/07
    If its a hatch, remove the trim at the rear of the boot, remove part of the rubber seal, remove the little popper just below the speaker shelf, remove the boot carpet and it just pulls out from the bottom
    Oct 2010
    Lincoln
    Many thanks, it's a hatch so I'll have alook 2moz
  1. ignition live fuse in under bonnet fuse box
    By TimTay in forum Electrical & ICE (including SatNav)
    Last Post: 13th August 2011, 15:19
  2. What does fuse 26 do in the engine compartment fuse box?
    By rich05uk in forum Troubleshooting
    Last Post: 8th January 2011, 22:02
  3. any-one with EPC access
    By mhvcbv in forum Electrical & ICE (including SatNav)
    Last Post: 14th June 2010, 14:38
