Results 1 to 10 of 18
Thread: starting problems 1.9cdti 8v
    Regular Member Turbomanrony's Avatar
    Sep 2010
    LEEDS
    Default starting problems 1.9cdti 8v
    every morning my vectra wont start takes ages and struggles evern with a new battery but once its running its fine!!
    im thinking it could be injectors as the heaterplugs have been changed.
    has any 1 has simmlar problems??
    Dartford
    it turns over alright then ? not struggling?
    Sep 2010
    LEEDS
    well it turns but not as fast as it should be just feels like its struggling and makes noises
    PRESTON
    could be the starter motor on the way out!
    Sep 2010
    LEEDS
    it takes few minutes to start the car its not the starter it trys to fire,
    leeds
    Hi, i am having exactly the same problem at the min. Driving me mad sometimes i have to take the air in take off and use spray to start.
    We have recently done alot of work as the cam pully broke and sent it out of time we had to replace a couple of valves and hydrolic lifters. Any way the problem is first thing on a morning or if it has been stood for a few hours. We are investigating it tomorrow and will keep you updated.
    Dumfries and Galloway Scotland
    Hi I had the same problem, iIput up with it for months tried all sorts, it turned
    out to be the Starter Motor only reason I found out is it got stuck. Changed
    it and what a huge difference. I would never have believed it as it turned
    over fine just took a long time to fire I thought.
    It went from starting on about the 10-15 turns of the engine to just 2.
    Best £120 I ever spent for a knew starter.
    Sep 2010
    LEEDS
    Quote Originally Posted by lightfx View Post
    ye iv heard the starter motor cloggs up with dust fronm the clutch and dirt.
    might giv it try sometime this week.
    Jun 2009
    Dover
    Mine has the same problem.But if I turn the key to ignition and wait till the buzzing noise from the tank will stop it's starts straight away.Do You have the same thing?
    Nov 2010
    Cheshire
    if it is turning over but wont fire or struggles to , change your heater plugs , a very very fiddly job on this engine 2 are easy to do but the other two are kinda blocked in by injector pump, if you put ignition on and off a few times and it starts fine thats your problem try that?
  1. starting issues 1.9CDTi 8v
    By Kevinw29 in forum Engine & Drivetrain
    Last Post: 14th October 2011, 08:10
  2. 1.9cdti whine when starting
    By mann3210 in forum Engine & Drivetrain
    Last Post: 12th July 2011, 12:16
  3. Vectra 1.9cdti starting problems
    By Dale1 in forum Engine & Drivetrain
    Last Post: 20th June 2011, 14:29
  4. 2006 1.9cdti Cold Starting Problems
    By rjcotterill in forum Engine & Drivetrain
    Last Post: 7th June 2011, 16:15
  5. 1.9CDTi starting problems
    By 3961bobking in forum Introduce yourself.
    Last Post: 7th June 2010, 09:26
vectra 1.9 8v takes ages to start
vauxhall vectra 1.9 cdti starting problems
https:www.vectra-c.comforumshowthread.php120990-starting-problems-1-9cdti-8v
vauxhall vectra 1.9 cdti starting problems when cold www.vectra-c.com
vectra c 1.9 cdti starting problems
