Results 1 to 10 of 11
Thread: crunchy gearbox
    Apr 2006
    Quinton
    Default crunchy gearbox
    another problem to share
    Doeas anyone suffer from a crunchy gearbox between 1st and 2nd, and 2nd and 3rd ?????
    I have a vec 05 1.9cdti sri and when it's cold the box is as crunchy as anything low down. Seems to go ok when it warms up!
    Reason for concern or just a cheeky vec trademark ???
    Nick
    nick , get it into your dealer mate ..... in the past we ( well alot of us ) have had problems with gear boxes ...
    Full Member lochgilp's Avatar
    argyll
    Nick, mine is the same mate, i was just speaking to another member about it! i will be booking mine into the dealer this week myself
    Apr 2006
    Quinton
    cheers for the advice guys. I'll mention it next time it throws a fault light ( which is almost weekly over the last few weeks )
    Nick
    Regular Member e.shine's Avatar
    May 2006
    essex
    its the 6 speed box that is the worst but i can tell you that they all do it some are worse than others though my 20 t had a new gearbox and clutch and flyeheel and still does it but my mind was put at rest when when i made an apoitment with tech from vauxhall nice bloke and very fare offered me yet another box if i wanted but explained that is how they are hardly notice it now i have stopped worrying about it
    Regular Member v6boy's Avatar
    PRESTON
    Trim : GSI
    My gear box is a right pig mate, more when its cold rather than warm, if i'm pulling up to a junction or traffic lights i keep the clutch dipped, cause if i let it up and then depress and try and put it into first its a nightmare
    Inverurie
    Quote Originally Posted by Nickzx6r
    Nick
    Ah, this is exactly what mine does and have been living with it. Me thinks a trip to Aberdeen maybe called for. B****r!
    Andy
    Regular Member BigP's Avatar
    Apr 2006
    Heated, Electric Recaro Leather
    Mines exactly the same, local dealer adjusted the linkage which has improved it greatly, still a little crunching on really cold mornings. Will get them to look at it again when the weather gets colder.
    Regular Member ion's Avatar
    walsall
    Mine does not do that at all, deffo get to the dealers.
    I believe some gearboxes were from Saab & were not up to the job, but were later changed due to the high failure rate.
    Mine changes perfectly in any weather, unless I miss the gate completely.
    Vehicle : i500
    Trim : i500
    Engine : V6 3.0CDTi
    yes my went after 4800 miles 3 and 5 gear but not that bad
    throw a lot of info at VX and told them i now you are having problems with the F40 gear box and I now that you have had a bad batch and are changing
    this problem
    came back 20mins later been onto VX and we will fit a new box when we get it
    link to when i found some info on the gearbox
  1. M32 gearbox can`t get gear selector back in gearbox HELP!
    By v33tra in forum Engine & Drivetrain
    Last Post: 30th March 2017, 07:43
  2. Squeeky and crunchy braking noise
    By m8internet in forum Suspension, Wheels & Brakes
    Last Post: 11th November 2009, 21:29
  3. 1.9CDTI Crunchy gearbox
    By GoldenWonder in forum Engine & Drivetrain
    Last Post: 2nd February 2008, 17:34
