Thread: check safeguard.
    Regular Member dansri's Avatar
    Jul 2010
    doncaster
    Default check safeguard.
    when fitting my rear interior light in pulled the tape an damaged this does any one know if this could be anythig to do with the check safeguard message if so hown can it be repaired? thanks. cant upload my pics but this is similar the part under the blck stuff exept mine didnt have the blck stuff it scome apart there are 3 like solder nblogs wich used to hold it together.
    Jul 2009
    The Rift, Cardiff
    If you have the alarm sensors by your light check the connection on top of the light assembley first.
    Jul 2010
    doncaster
    yeah ive got the sensors near the front interior light ive tried pushing the connector in. tried loccking he car with the windows down and sticking my head in, the alarm doesnt go off. the red light on the dash still flashes. the pic above is in the roof lining above the passanger rear door do you know what they are all for? cheers anything there to do with the alarm?
    Jul 2009
    The Rift, Cardiff
    When I fitted my rear int light there were 2 plugs, if you look on the ribbons it will say what its for, one for rear light (Dome) one for the parking sensors (park assist[i think]).
    I also slightly pulled apart the same thing you did, no black on mine either. I just pushed it back together and hoped for the best. It might be repaireable and its worth trying but I think i've read on here that some have had to buy a new roof loom.
    Edit, Its also worth checking the connection of the roof loom ribbon with the fuse box in the boot, it might have been pulled out slightly when lowering the roof lineing.
  1. Safeguard Check.
    By Saxman in forum Electrical & ICE (including SatNav)
    Last Post: 3rd July 2012, 17:43
  2. Check Safeguard
    By Tam80 in forum Engine & Drivetrain
    Last Post: 24th April 2011, 08:43
  3. Check Safeguard
    By DaveG in forum Electrical & ICE (including SatNav)
    Last Post: 31st January 2011, 22:51
  4. Check Safeguard
    By BaileySRI in forum Electrical & ICE (including SatNav)
    Last Post: 1st March 2010, 22:41
  5. Check Safeguard (Again)
    By stevem in forum Troubleshooting
    Last Post: 6th August 2008, 19:31
safeguard fault vectra c
check safeguard vauxhall vectra
грешка check safeguard opel vectra
https:www.vectra-c.comforumshowthread.php120979-check-safeguard
safeguard check vectra
