Thread: Glowplugs snapping
    Bristol
    Default Glowplugs snapping
    Is this a common thing on the dti?
    Anyway I can stop it from happening?
    What's the solution if it does happen?
    Just had a garage effectively turn down the job as they've had it happen in the past, which doesn't fill me with confidence in doing it myself.
    West
    Did mine myself on all my old dti's... pre soak whith plenty of wd40 overnight, warm the engine slightly prior & just take it slowly... the 1st sign of a thread stripping remove instantly
    Oct 2010
    cumbria
    hi just done mine in my 2.2 DTI and i was sh**in them when i done them but got them all out with out them snapping got very good advice of this site. i used lots of wd 40 and a 1/4" socket set with 10mm long socket. i didn't want to use a 1/2" drive ratchet with the 1/2 drive i think you would get to much pressure on them and i would be so easy to snap them just take your time make sure the engine is warm to
    Vehicle : Signum 2.0 DTi
    Trim : Elegance/Elite
    Engine : 2.0DTi
    Mileage : 73350
    As above
    just did mine this week drove car around the block to warm it up , remove turbo heat shield , then remove glow plug caps .
    Spray each glow plug with wd40 before using a long reach 10mm socket on an extension bar that way you can let the bar find its own allignment.
    this works on three of them , the fourth one you best remove turbo hose from camshaft cover first then by just using socket and rachet only slowly apply torque until glow plug gives .
    Bristol
    Vehicle : CDTI 150
    Best to use a penertrating oil e.g. Plusgas (WD 40 is a water dispersent, hence WD) on a cold engine, leave preferably overnight.
    Next day get the engine warm and using sockets as directed above.
    Agree with a 1/4 drive. Ensure you keep everything 'square' so that you are only applying a turning force not one pushing sideways.
    Good luck
    Regular Member signumturbo04's Avatar
    SCOTLAND
    even more effective than wd40 is to soak them in coca-cola over night. and it has to be the real stuff lol doesnt work with cheap cola. after soaking overnight they come out a dodel
    rothwell leeds
    Vehicle : vectra c
    Trim : sri
    Engine : 1800 vvt
    last ones i did i sprayed them with neat cilit bang let it soak in over night then slightly warmed up engine... good quality snap on 1/4 drive socket (deep) and out they came
    Bristol
    Vehicle : CDTI 150
    BANG and the plugs came out............
    Regular Member DaveW555's Avatar
    Cannock
    when you put the new plugs in copper slip the threads, should stop any ceasing for next time as copper slip can withstand temps of up to 1000 degrees c.
    Oct 2010
    cumbria
    when i done mine got them out but the thread's were damaged so had to re tap the head with with a m10- 1 the one is the pitch of the tap so you have m10 taps that are fine and coarse m10-1 m10-1.25 m10-1.5
  1. odd snapping/breaking sound coming from the front brakes
    By Blurry120 in forum Suspension, Wheels & Brakes
    Last Post: 2nd June 2012, 17:57
  2. Dti Glowplugs
    By Dazzy2006 in forum Engine & Drivetrain
    Last Post: 2nd December 2010, 20:20
  3. Maybe more then Glowplugs
    By danny1992 in forum Engine & Drivetrain
    Last Post: 24th November 2010, 15:37
  4. Why do I only hear of Vectra springs snapping?
    By Vaux-Man-G in forum Vectra C / Signum Car Chat
    Last Post: 13th August 2009, 16:32
  5. my little spring snapping story.....
    By ks246 in forum Vectra C / Signum Car Chat
    Last Post: 14th May 2009, 20:47
