Thread: Outside temp sensor
    Oct 2010
    Lincoln
    Default Outside temp sensor
    Can someone tell me where this is located on a 56 plate 3.0CDti? Just noticed that I have the F displayed so assume the sensor has gone or has become disconnected. Hope this isn't linked to my door switch light problem
    Full Member Caveman_nige's Avatar
    Jun 2009
    South Coast
    Vehicle : Vectra and a Signum
    Engine : Z18XE,Z19DTH,Z20NET
    lower grill half way up about 20cm in from the NS
    Regular Member bobobaldy's Avatar
    Oct 2009
    lanarkshire
    Alright i have the same problem but whats the best way to get into it .I have the face lift model?
    Oct 2010
    Lincoln
    Is it easy to get to from the front? Don't have to take the grill etc off?
    Oct 2010
    Lincoln
    Just had a quick look and there is nothing connected to it!! I can feel the connector lying at the bottom but I can't see how to get my hands in to reconnect it?
    Jun 2009
    South Coast
    its a tricky one to get to, i get at mine from underneath and reach in from around the NSF foglight area
    Oct 2010
    Lincoln
    Thanks, I'll give that a try. ****** annoying that you can feel the connector and see the sensor but there appears to be no way to get your hands in to reconnect
    Oct 2010
    Lincoln
    What a sod of a job! Had to get my grandson to do it in the end as he was the only one with small enough arms to get in there
  1. outside temp sensor
    By andy_richmond in forum Vectra C / Signum Troubleshooting
    Last Post: 30th September 2012, 14:09
  2. Outside Air temp sensor........
    By Mark@Elite in forum Vectra C / Signum Troubleshooting
    Last Post: 4th February 2012, 16:20
  3. Temp sensor
    By dezzyb66 in forum Engine & Drivetrain
    Last Post: 21st November 2011, 21:23
  4. Outside temp sensor
    By xf8u39 in forum Electrical & ICE (including SatNav)
    Last Post: 2nd January 2011, 17:35
  5. Temp Sensor
    By ghostrider in forum Electrical & ICE (including SatNav)
    Last Post: 7th May 2006, 22:45
