Results 1 to 10 of 19
Thread: making a diesel faster ?
    Oct 2010
    n.i
    Default making a diesel faster ?
    best mod's to take a 120 in around the 180bhp mark?
    also will this make the car reek more as i heard when increasing the performance on a diesel it can cause it to smoke more?
    preston
    i'd
    derestrict air box
    clean egr, boost sensor, maf sensor, throttle body
    make sure vaccum pump ok & check all vaccum hoses
    new air filter, oil filter , fuel filter
    clean intercooler and make sure all hoses ok
    that should get things ready for next stage
    get a good quality remap
    then use a good fuel from then on
    I use V power but BP Ultimate is just as good
    to make sure you can make best use of that power, i'd consider upgrade to suspension too and also go for 314mm brake upgrade
    a long list of things but thats what i'd do
    Oct 2010
    n.i
    suspension + brakes would already have been taking care off anyway
    anything else i could do?
    Regular Member ANDY W's Avatar
    May 2007
    WINSFORD
    A quick fix is to fit a tuning box like a DTUK or a Caterman as it is called on here otherwise its a remap but to still get more I think you need to get a larger intercooler as this was the next stage on my 1.9 150 after my remap but afetr that I have no idea. You could speak to Ian at MPG or Regal as both of these companys are VX mad. I also forgot about Thorney aswell.
    Liverpool
    Quote Originally Posted by mparks8590 View Post
    i'd
    derestrict air box
    also try induction kit, or just k&n panel filter
    power flow exaust with cat bypass
    if money is no object......... bigger injectors, higher pressure fuel pump, larger turbo, intercooler upgrade
    and with more power,dont forget you need to put it down, so get a decent set of tyres/wheels and some decent brakes (my next mod)
    orrrrrrrrrrrr forget what everyone has said, go out and by a 150 1.9 and put a tuning box on and job done ovr 180 bhp lol
    Regular Member Rab's Avatar
    Irvine
    airbox mod + K&N panel filter
    good service
    good remap
    RR day
    fuel wise buy millers diesel additive turns normal diesel into Vpower and its an injector cleaner etc aswell. alot cheaper than running vpower etc.
    after that its a bit more expensive for less gains
    start with the basics.
    diesel reek is part and parcel just think of it as a james bond smoke screen lol.
    Regular Member dominic32's Avatar
    Oct 2007
    whitstable
    push it off a cliff
    Oct 2010
    n.i
    diesel reek is the one thing putting me of more power, if i do get it up around 180bhp should i expect diesel reek?
    Liverpool
    Quote Originally Posted by stevie-m View Post
    unless your foot is perminantly going to be welded to the floor, you shouldnt have a problem mate
    Feb 2007
    North west
    with an 8 valve and no swirl valves ect just be careful you dont end up with all top end pull and no mid range, to get an extra 60 bhp your going to work it really hard. Mate at work had a highly tuned 120 (he drove it really hard BTW) and he blew the gearbox.
  1. go faster GSi
    By Swatty in forum Vectra C / Signum Car Chat
    Last Post: 14th June 2011, 19:54
  2. faster
    By bob-ali-cia in forum Diesel Engine related
    Last Post: 22nd January 2011, 09:07
  3. making my vecci faster!!!
    By damadom in forum Petrol Engine related
    Last Post: 13th February 2009, 07:07
  4. Go faster Micra.....!
    By Vaux-Man-G in forum The 'Off Topic' room
    Last Post: 27th November 2008, 13:52
  5. faster !
    By gazz1a in forum Vectra C / Signum Car Chat
    Last Post: 2nd April 2007, 21:23
