Results 1 to 10 of 27
Thread: starting problems 2004 vectra 1.9 deisel
    Oct 2010
    gosport
    confused starting problems 2004 vectra 1.9 deisel
    Hi there everyone,very good forum with lots of interesting stuff and hopefully someone can help me before the stealers tries to rip me off!!
    as mentioned abve I have a 2004 vectra 1.9 diesel which is hard to start in the morning or if its left for a few hours.have to crank the engine for a while then engine starts with white smoke coming out of exhaust an smell of unburnt diesel.had new glow plugs and relay fitted when stealers done the service in feb this year,have had it back several times to try to resolve this issue.they now tell me that one of the shims is tight(???)and also the camshaft is slightly worn(done 89000 miles)and that the egr valve could be sticking.to replace camshaft ,shim and egr they have quoted me over £1200 with no guarantee that this will cure my problem.,getting really fed up with this as the car drives fine when started and i'm sure they're just trying to take more money off me as they tok £900 at my last service.any one got any ideas or know a good mechanic in gosport who could look after my car for me as i'm totally fed up with vauxhall.
    all help and answers would be greatly appreciated before the wife kicks me to the kerb,i'm an engineer but have no knowledge of diesel engines,many thanks in advance
    john higgins
    West
    You need to find a diesel specialist who can test the injectors for you, that's what i'd be looking into
    Oct 2010
    gosport
    thanks for the quick response,all answers gratefully received as i'm at my its end with this,should have kept my landy,never let me down once but the wife hated it!!
    Full Member
    Jun 2007
    N/A
    Vehicle : Golf 7
    Trim : GTD
    Engine : 2.0 TDI 184PS
    Mileage : 40000
    A worn camshaft at 89k? Personally I would be sceptical but as mentioned I too would be suspecting the injectors.
    Gazza4
    Oct 2010
    gosport
    i have been very skeptical about eden since they done my service as they said my radio was knackered and would need a new cage and also the solonoid for heating wasn't working and they told me the part would cost £120 !! I fixed the loose aerial plug on the stereo cage and freed of the sticking heater vent arm on the solenoid with some wd40.thats why i am asking for advice as i think they are trying to rip me off !!!
    preston
    is this a dti?
    leak off pipes maybe?
    white smoke suggests water in system.
    have you changed fuel filter recently .....
    Oct 2010
    gosport
    i'm not sure if its a dti,gotta wait for stealers to put it back together tommorrow b4 i pick it up
    preston
    go to eurocarparts website
    put reg number in and it will tell you what you have
    i think dvla website does this but i find eurocarparts quicker
    Full Member
    Jun 2007
    N/A
    Vehicle : Golf 7
    Trim : GTD
    Mileage : 40000
    Your profile says 1.9, only the CDTI comes in this engine size. The DTI is either 2.0 or 2.2.
    Gazza4
    stockport
    Arrow
    Quote Originally Posted by mparks8590 View Post
    is this a dti?
    Regarding the fuel leak off pipes suggestion,which means air is leaking into the system,(which sounds very much like it is your problem),go through the air bleeding process=turn ignition on for 15 secs then turn off.Repeat this another two times,(so three in total),then start the car,If it starts ok then that's your problem.
    You can buy a replacement kit very cheaply from eBay or your local motor factor.Best of luck,FELIXX.
  1. Vectra 2.2 DTI SRI Starting Problems
    By althekid in forum Engine & Drivetrain
    Last Post: 4th January 2013, 20:41
  2. problems with vectra 2004 diesel 120bhp
    By DavyB in forum Vectra C / Signum Troubleshooting
    Last Post: 29th February 2012, 11:03
  3. Vectra 1.9cdti starting problems
    By Dale1 in forum Engine & Drivetrain
    Last Post: 20th June 2011, 14:29
  4. Vectra 2.0 dti Starting problems
    By willias233 in forum Engine & Drivetrain
    Last Post: 8th February 2011, 20:06
  5. Vectra 2.0 dti starting problems
    By daveymaboy in forum Engine & Drivetrain
    Last Post: 31st March 2009, 15:43
