Thread: water in passenger foot well
    Kent
    Trim : SRI
    Engine : 1.9 CDTI 150
    Default water in passenger foot well
    Help with this one..
    estate 2004 1.8 petrol
    the passenger side foot well is getting wet from wome where but not sure where from
    i have not had the car long so dont know how long its been like it, i collected the car and found the leak then.
    i have checked the normal, the heater matrix i can see it leaking as the carpets not wet under the matrix box.
    the cars not losing any water from the coolant bot.
    i have checked the drain plug by the pollen filter and are clear.
    any ideas please?
    Oct 2009
    portland
    Vehicle : Bmw 330d
    Trim : Msport
    Engine : 3.0d
    badly fitted windscreen can leak water in
    Jan 2010
    glasgow
    if its that bad a leak dry it out best you can and get some 1 to hose it as you sit in the car and look for the said leak are you defo sure the rear foot wells are dry? as sometimes they leak from the rear quarter windows
    Kent
    Trim : SRI
    Quote Originally Posted by hoochydady View Post
    the rear is deffo dry mate checked that one. i have removed the glove box and still unable to see where its coming from did this with a hose pipe on the car and couldnt work out where its coming in from.
    Quote Originally Posted by mattv6diesel View Post
    any way to check its the windscreen? would have thought i would have got wind noise from the screen? which i dont
    Kent
    Trim : SRI
    also to mention the pollen filter and area where the drain plug is ment to be was bone dry when i checked today but the carpet was still full of water
    stockport
    Arrow
    Quote Originally Posted by ricky1 View Post
    When you say "meant to be",does this mean you have actually made sure that the scuttle drain IS clear?,because this problem sound like it IS blocked.If it is blocked you may end up having problems with your blower fan/motor.I had a"stiff"motor because of a similar problem with water ingress,and it rusted the blower motor.That problem kept blowing resistor fuses so I sprayed the motor/fan through the pollen filter access with WD 40 and I have had no failures since.(Just thought I would add that snippet!!.FELIXX.
    Kent
    Trim : SRI
    Quote Originally Posted by felixx View Post
    by meant to be i mean i have removed it, just to rule out the lip.
    Kent
    Trim : SRI
    Fond he leak turned out to be a small hole in the glue for the windscreen in the top passenger side and as it rained it just come in slowly.
    only found it by chance where i had the kick panel of and i could see the water dripping and removed the door rubber sill and could see where it was starting to come from removed the a piller trim and bingo.
    now time to dry the car out and removed the smell
    Regular Member old cruiser's Avatar
    slough
    Result there mate well spotted, have you sealed it back up with silicon sealant?
    Cheers Pete
    Kent
    Trim : SRI
    Quote Originally Posted by old cruiser View Post
    Cheers Pete
    I meet up with a mate of mine with some windscreen glue and sealed it back up with that
  1. Passenger Foot Well
    By connor748 in forum Vectra C / Signum Car Chat
    Last Post: 28th January 2017, 20:23
  2. water in passenger foot well
    By crayon in forum Bodywork & Interior
    Last Post: 28th January 2011, 13:31
  3. There’s water in the passenger foot well
    By Tadpole in forum Vectra C / Signum Car Chat
    Last Post: 17th March 2010, 22:36
  4. Vec 3.2...water on passenger side foot thing...
    By vec3.2 in forum Vectra C / Signum Car Chat
    Last Post: 28th August 2009, 09:16
