Results 1 to 10 of 22
Thread: Knocking noise from Front Wheel
    Regular Member lostdog's Avatar
    Oct 2010
    Midlands
    Default Knocking noise from Front Wheel
    I have a question.....
    I have noticed a very slight knock sound on the passenger front wheel. And also the steering pulls a little to that side. To the left while driving.
    It does not do it all the time and not just over bumps in the road.
    Does anyone know what this may be?
    Wheel Bearing? Track Rod End?
    I want to repair it myself to save money.
    n.ireland
    My vectra c has just started making the same small knocking noise on the front passenger side wheel. gonna in spect it now.
    Oct 2010
    Midlands
    would like to know what you find...........pictures too please?
    Regular Member yysnet's Avatar
    Jul 2010
    Scotland
    May be damper....
    Regular Member djr69uk's Avatar
    Midlands
    i'm guessing play in drop link
    north east
    Probably a drop link and best to replace anti roll bar bushes while you are at it.
    n.ireland
    well i jacked my vectra up this afternoon and gave everything a good wiggle about and all felt nice and tight, went a drive there now and the passenger side front is knocking and getting a wee bit louder. i think its either the shock, bushes, ball joint ( but this looked pretty tight and good). I'll have to investigate further. anybody have similar problems
    Aug 2010
    Leeds
    Whats the mileage and the year?
    This could be a few things it's better to pin point it rather than whacking parts on which gets pricey.
    preston
    are you're springs ok....
    also check top mount bolts and centre bolt......
    have wheel nuts been tightened up?
    just some things i'd check in addition to above
    north east
    If its the drop links you will hear the noise when that side is raising and dropping eg over a speed bump is perfect testing ground. Unfortuantly they look fine but when they are going a little tug and they ball joint falls to pieces.
  1. Knocking Noise When Turning Wheel
    By sligo_eire in forum Vectra C / Signum Troubleshooting
    Last Post: 2nd June 2014, 05:58
  2. Big knocking noise from front
    By waynerl in forum Suspension, Wheels & Brakes
    Last Post: 1st October 2012, 16:54
  3. 4 Wheel alignment and knocking noise
    By man on the moon in forum Suspension, Wheels & Brakes
    Last Post: 21st August 2008, 23:23
  4. Knocking Noise from Front
    By mark1319 in forum Suspension, Wheels & Brakes
    Last Post: 12th February 2008, 15:54
  5. Front knocking noise over speed bumps
    By korlinski in forum Vectra C / Signum Car Chat
    Last Post: 8th June 2007, 08:25
vectra c knocking noise from front
vectra c front end knock
vauxhall vectra wheel knocking
vectra c front suspension knocking
vectra c knocking on offside wheel when Signum knock when wiggle steering wheelsignum 2003 knock under wheelvectra c anti roll bar knockingvectra c front knock turning left iver bumpknocking on front wheel vectra c vectra c noise on passenger sidefront pipe knocking on vectra cknocking on front suspension vectra cvectra banging at front on bumpsvauxhall vectra front knocking noisevectra c front knockingknocking noise from my vectravectra c making noise from front when over 30vectra c front wheel noise2005 vectra front makes a knocking noisevectra c front knocking noisehttps:www.vectra-c.comforumshowthread.php120884-Knocking-noise-from-Front-Wheel
