Thread: Anyone Help Please
    Regular Member Badger59's Avatar
    Sep 2010
    Telford
    Default Anyone Help Please
    Hi got a problem the warning light on the dash, its showing the rear driver side as open when its shut!
    Anyone have any idea how to sort it out? Because itís showing the door open the interior light wonít go off, switched it off manually but the mileage light stays on
    north east
    2 blue fuses in the boot take them out and put them back in.
    Sep 2010
    Telford
    Quote Originally Posted by roswell View Post
    Sorry were will they be, only just had the car
    north east
    open the boot you will see a panel on the left side with a green cross on it (for a first aid kit but you probably wont find one thier)
    Open the panel and all the fuse are thier :-)
    Sep 2010
    Telford
    anyone?
    Please, pulled out the blue fuses still on
    WGAF#5
    in that case your probably going to need a new lock as the sensor is integrated into the door lock
    where old cars had the plunger to detect the door being open whilst moving there now built into the lock assembly.
    Sep 2010
    Telford
    Thanks Mate,
    Iíll contact the dealer tomorrow, its still under Warranty, must be a bad day just come back from the shop and the cruise control wonít work!!!
    north east
    cruise control is probably the clutch pedal not being fully up, put your foot under it and gently lift it up when pressing the cruise control, if that works take it back to vaux ;-) you need either a new clutch return spring or a new pedal.
    Regular Member keefy*2010's Avatar
    Jul 2010
    Grain, Rochester,Kent
    Vehicle : Vectra C Facelift
    Engine : 1.9Cdti 150
    Remember you must have used the the footbrake once before the cruise control will activate
    Also make sure you have not got your feet anywhere best brake or clutch pedals as they both have switches on them.
    Sep 2010
    Telford
    Quote Originally Posted by keefy*2010 View Post
    Had used the brake, the light flickered but thats all
