Thread: 1.8 vvt
    Regular Member bedo13's Avatar
    Oct 2009
    EgypT
    Default 1.8 vvt
    Hello every one..
    I heared about this engine 1.8 vvt but i dnt know much about it..
    Can any1 help me , what is its spec. Bhp,torque, code, models containing it and any other info..
    Is it similar to the Civic's one wih 140 bhp?
    Thanks,
    Oct 2009
    Luton
    Z18XER - Astra-H/Zafira-B/Vectra-C/Signum
    A18XER - Insignia
    Fam 1 engine, development of the old Z18XE but with variable valve timing.
    IMO works well in the Astra but lacks the low end torque for Zafira / Vectra / Signum.
    Regular Member nibblitz's Avatar
    Jul 2010
    Buckinghamshire
    Regular Member Exclusive BV's Avatar
    West Midlands
    its not actually a bad engine in the vectra, it all depends on what you are used to and what you want.
    Its not the fastest, not the most tunable or the most economical with only 500 odd miles to the tank but..................
    it dont break much either.
    VIP-Member Das's Avatar
    Yer Maws Bedroom
    40 Post(s)
    Vehicle : Honda Civic
    Engine : 1.8 Vtec
    Mileage : 64500
    Quote Originally Posted by Exclusive BV View Post
    There are people on here with Diesel Vec's that get less than that though and im not on about v6 diesels either
    Quote Originally Posted by I cdti View Post
    Do you know if the plastic engine cover from the Z18XER is a direct replacement for the one on the Z18XE? Its a far nicer looking one, all the holes do look like they are in the same place too.
    Oct 2009
    Luton
    Do you know if the plastic engine cover from the Z18XER is a direct replacement for the one on the Z18XE? Its a far nicer looking one, all the holes do look like they are in the same place too.[/QUOTE]
    Don't think so, but can check tommorow for you
    Yer Maws Bedroom
    40 Post(s)
    Engine : 1.8 Vtec
    Mileage : 64500
    Don't think so, but can check tommorow for you[/QUOTE]
    If you could that would be great.
    Oct 2009
    Luton
    Z18XE & Z18XER engine covers are a different design.
    The Z18XE has a much bigger plastic cover that covers the complete head.
    The Z18XER has a small cover that fits between the cams, leaving the cam housing exposed.
    Yer Maws Bedroom
    40 Post(s)
    Engine : 1.8 Vtec
    Mileage : 64500
    Thanks for checking anyway.
