Thread: How to remove accelerator pedel
    Regular Member ANDY W's Avatar
    May 2007
    WINSFORD
    Default How to remove accelerator pedel
    Does anyone know how to remove the accelerator pedel ( rubber ) the part you put you foot on and not the how thing. I did do this once to fit a aftermarket pedel cover but now I am fitting Insignia ones but the memory has totaly failed AGAIN. Just for your info the Insignia large brake pedel cover that is in the auto's does fit and as a added bonus its the SRI/ VXR type so well chuffed as Irmscher failed to cator for us auto guys.
    Full Member
    Jun 2007
    N/A
    Vehicle : Golf 7
    Trim : GTD
    Engine : 2.0 TDI 184PS
    Mileage : 40000
    The insignia cover fits over the rubber cover which is already there. First of all fit the top part of pedal (the rubber bit) over the top of the rubber bit on the pedal, then prize the rest of rubber lip round the pedal. That's what I did.
    Gazza4
    May 2007
    WINSFORD
    When we say rubber do you mean the hard plastic bit because that is what I meant. I have now taken the pedel bit out has I had to get behind it to remove some nuts that were holding the aftermarket cover on. The Insignia cover has a word OBEN in it does that mean top or bottom or neither
    Full Member
    Jun 2007
    N/A
    Vehicle : Golf 7
    Trim : GTD
    Mileage : 40000
    Quote Originally Posted by ANDY W View Post
    I put the OBEN bit to the top. You just have to patiently prize the rubber lip (albeit feels like plastic) on the Insignia cover around the pedal cover.
    Gazza4
    May 2007
    WINSFORD
    Right ok, now the Insignia cover has rubber flaps which I suppose should wrap around the pedel so do you need to trim the oe pedel just to be sure of a decent fit
    Full Member
    Jun 2007
    N/A
    Vehicle : Golf 7
    Trim : GTD
    Mileage : 40000
    Nope m8 they will fit you don't need to cut or anything just patiently keep trying and you will eventually get the cover fitted.
    Gazza4
    May 2007
    WINSFORD
    I have now got it fitted but as I was saying the rubber flaps of the Insignia cover dont really fit that well at the sides so should I trim the Vectra part or will it be ok or am I just being a fussy ass
    Full Member
    Jun 2007
    N/A
    Vehicle : Golf 7
    Trim : GTD
    Mileage : 40000
    I would leave it m8 it should be ok.
    Gazza4
    May 2007
    WINSFORD
    Ok matey will do and thanks for your help, just shows what a damm good site this is.
    Full Member
    Jun 2007
    N/A
    Vehicle : Golf 7
    Trim : GTD
    Mileage : 40000
    No worries bud.
    Gazza4
  1. No reaction to accelerator
    By Kaz in forum Engine & Drivetrain
    Last Post: 15th January 2013, 22:58
  2. Accelerator pedal
    By Mopar Man in forum Diesel Engine related
    Last Post: 8th December 2011, 20:41
  3. intermittent clutch pedel
    By andd306 in forum Vectra C / Signum Troubleshooting
    Last Post: 19th July 2010, 22:17
  4. accelerator goes 'flat'
    By Videoman in forum Engine & Drivetrain
    Last Post: 30th October 2009, 12:22
  5. no accelerator!!!
    By alexgrfc in forum Engine & Drivetrain
    Last Post: 5th November 2008, 22:38
