Results 1 to 10 of 16
Thread: Does your vectra steam up?
    Aug 2010
    Leeds
    Default Does your vectra steam up?
    Think this car has spent 6 months under water im for ever putting the air con on to clear the windows in the colder weather the pollen filter is clear.
    Looking at a few other vectras in the car park and there rear and front screens were same as mine!, Is this poor design is yours the same.
    No garage stuck outside like all my cars have but this is the worse for this i park it in the sun and leave a window slightly open to clear.
    Regular Member RobertHayman's Avatar
    Sidmouth
    Vehicle : Insignia
    Engine : 2.0 CDTI auto
    Year : 63
    Mileage : 8,500
    Mines OK, 58-reg.
    You could have damp inside for it to condensate on the windows.
    Use the aircon and heater together to dry the air inside.
    Halstead, Essex
    Same here...now almost every morning. And I hate that I have to use the aircon when it's already so cold outside. I'll try some FOG X and Rain X in the near future.
    Oct 2009
    Luton
    Check the spare wheel well....
    Sep 2010
    Hartlepool
    Quote Originally Posted by cj_quest View Post
    I think you might have to turn it to warm, especially to dry the air inside the car.
    north east
    Check the drain holes under the scuttle panel,
    Change the pollen filter if wet.
    if you have the heaters on run some cold air through them before gettign out of the car.
    Sep 2010
    doncaster
    hi iv got a 05plate signum and its just started doing that i dont realy use the air con cud it be a filter of sum sort?
    WGAF#5
    another Tip - if you have rubber mats its a vicious circle
    the water pools on the rubber mats when you get in with wet feet and clothing etc..... the heater heats the water then it evaporates and wanders happily around the interior of your car until you get out and then the glass gets cold first and then condensation is formed on the glass - you get back in and the cycle is repeated .....
    use a cloth to dry the glass thorougly and check around your boot area where water accumulates to make sure you have got it all ....you may have to repeat the cycle a few times to get rid of the worst of it ..then make sure you replace the rubber with carpet as it absorbs the water better
    and also make sure you still use your ac/climate on heat as this will help to dry out the interior of your car and also prevents the ac seals on the pipes from failing through lack of use in winter months
    Jul 2009
    The Rift, Cardiff
    Mine was steaming up really bad a few weeks ago, but I removed the scuttle panel, wiper motor/linkage and unclipped the wire loom to remove all the compost from leaves and cleaned the blocked drains. Now all is good and normal.
    Regular Member Jonsey's Avatar
    Oct 2010
    Walkden, Manchester
    Me thinks I will have to do mine tonight, as it steams up quite badly even with 2 people in it.
  1. Steam cleaners
    By marc vectra sri in forum Detailing and Car Care Discussion
    Last Post: 8th June 2012, 17:08
  2. Steam Train
    By gaz1965 in forum Comedy & Humour
    Last Post: 14th February 2012, 12:26
  3. steam rally
    By yorkshireborn in forum General Chat
    Last Post: 5th August 2007, 13:26
  4. Radiator steam
    By vectrasri03 in forum Vectra C / Signum Car Chat
    Last Post: 6th March 2007, 22:25
