Thread: engine unbalanced
    Oct 2010
    york
    Angry engine unbalanced
    took car in yesterday as got vibration from front end when accelerating hard, vauxhall said that it could be one of two things, either the cam chain has jumped or it could be the flywheel in the gear box. When it does vibrate and you put the clutch in at this point the vibration goes away, can anyone help please?
    north east
    Check the front engine mount bottom of the gear box under all the rads.
    Regular Member DaveW555's Avatar
    Cannock
    If the cam chain had jumped it would either run really rough or maybe not at all so I think maybe you can rule that out as I take it the car still runs fine (apart from the vibration obviously). The DMF's do have small brass/copper weights on the back of them to balance the unit a bit like wheel weights, if one of these has fell off that would cause a vibration and possibly make it harder to get the gears. I had this problem when I changed my DMF there was no balance weights on the new flywheel and like a muppet I fitted it anyway thinking they'd made a perfect one (d'oh!! wont be making that mistake again lol) and it caused loads of problems with vibration and gear selection, even the clutch wouldn't disengage properly and all because of a silly balance weight.
    Forfar, Scotland
    Trim : LE/VXR
    Engine : 2.0 cdti/1.6 Turbo
    Year : 13/07
    It seems to be a common occurence for drive shafts to go on the Vec C, this would give you the same symptoms
    Vehicle : vectra-c
    Trim : sri
    Engine : cdti
    Mileage : 98,000
    You dont say what engine you have!, Could it be the cdti? . mine does it slightly under LOAD!. dmf, there crap.
  1. 1.9 cdti Z19DT estate engine juddering plus white smoke coming from engine bay
    By danedragger in forum Vectra C / Signum Troubleshooting
    Last Post: 25th January 2013, 17:44
  2. Can I replace a Z19DT engine with a Z19DTH engine, fairly easily?
    By Krusty3380 in forum Engine & Drivetrain
    Last Post: 13th August 2012, 15:24
  3. unbalanced tickover and burning smell
    By jofenan in forum Engine & Drivetrain
    Last Post: 20th May 2010, 22:07
  4. Replies: 3
    Last Post: 28th April 2009, 19:49
