Thread: Oil Change and now engine running cold?
    Cheshire
    Default Oil Change and now engine running cold?
    Hi all,
    Recently changed my oil for some fresh Mobile 5 30W, and ever sine it seems to be taking the car double the distance to get to normal running temp?
    Also, i have also noticed that when my heaters are on warm, and i turn right, the heaters blow cold for an second and then return back to hot?
    Very strange....
    Any ideas why it may be?
    Huddersfield
    The first one will probably be down to a drop in external temperature in the last week or so. I can't think how the oil will affect coolant.
    Not sure about the other point.
    Quote Originally Posted by Morzy View Post
    Quite normal
    Used oil contains fine particles of metal which retain temperature more easily
    New oil is able to transfer the heat away more efficiently
    WGAF#5
    heaters blowing cold momentarily on changing direction is also normal ...something to do with the height of the transmission tunnel
    I've never noticed any such change
    I normally run with the air con on, the temperature dial at between 12 and 1 o'clock positions, and speed to 2
    If I need hot air, then I increase the speed to 4
    WGAF#5
    do a search its quite a common query on here
    Do a search on here? Why?
    I use those settings I posted, never had any issue
    Feb 2007
    North west
    heat transfer is a really important part of an oils job - if it does it well so much the better. It will take longer to warm up if the outside air is colder - and the car temp gauge shows the water temp not the oil temp.
    Regular Member rushy's Avatar
    Vehicle : 9-3 Wagon
    Trim : Turbo Edition
    Engine : TID (1.9 16v)
    Year : 2010
    Mileage : 137000
    Hi all,
    Very strange....
    How much oil did you put in it?
    Cheshire
    Put in just under 5L
  1. Engine running on 3 cylinders on cold start
    By philc1210 in forum Engine & Drivetrain
    Last Post: 16th February 2012, 08:49
  2. cold start smoke and poor running engine
    By Tredici in forum Engine & Drivetrain
    Last Post: 16th January 2012, 08:40
  3. Oil Change - Hot or Cold Engine?...
    By snapsnap in forum Vectra C / Signum Car Chat
    Last Post: 15th March 2011, 15:00
  4. Running Cold
    By dc6839 in forum Bodywork & Interior
    Last Post: 29th November 2010, 18:43
  5. Cold running on 1.8 vvt
    By jasone in forum Engine & Drivetrain
    Last Post: 7th December 2008, 15:28
